700R4 Lost 3rd gear
Discussion in 'The Hokey Ass Message Board' started by Redtoptravis, Jun 9, 2013.
  1. Kinky6
    Kinky6
    Yeah, the additional info is always a good thing to have, but in this case, the OP hasn't been on here since last June. Hope he got his trans sorted by now. :rolleyes:
    Later, :cool:
  2. OLDSMAN
    OLDSMAN
    As others have said, this is not a kickdown cable, but a TV cable. Throttle valve cable. As an old automatic trans rebuilding man, I would guess that you have toasted this unit. It doesn't take very many miles to burn up a 700R4, or a Ford AOD with the TV cable either unhooked or not adjusted properly. Some will try and tell you to adjust them by shift feel, however the proper way is with a pressure gauge hooked up to the transmission. Good luck
