Technical 700R4 question
Discussion in 'Traditional Hot Rods' started by Yamanine, Feb 18, 2017.
  1. Yamanine
    Yamanine
    Hey guys, I'm wondering if any of you can help me out here? I'm running a SBC with a 700R4 (3 speed with overdrive) in an old 46 Ford hot rod. I noticed the ****** has a couple of electrical plugs. One is where the speedo cable would go, I'm ***uming the plug there means it has a pulse generator. Can I just take it out and throw a cable with the correct gear in it's place? The other plug from what I've read so far, is that it's for the torque converter lock-up. Will it still shift into overdrive if I don't hook it up? I don't have a computer for it, so I really don't know what to do . Thanks guys.
  2. Yes , you can convert it back over to gear driven speedo.
    Do a search on the lock up question.There must be 50 posts here.
    Short answer..Yes , all upshifts are controlled by the detent cable and governor
  3. Yamanine
    Yamanine
    Thank you sir!
  4. I should have said TV (throttle valve) cable. Excuse me.
    gimpyshotrods likes this.
  5. choptop40
    choptop40
    If you don't lock it up , you will burn it up....google it..I installed a pressure byp*** , to byp*** computer..just drop the pan and its an hour deal..200r4 no problem..700r4. Big problem without computer...
  6. You don't need a computer to lock up a 700 R4 converter. You byp*** the LU circuit lube for no lock up...not a computer.
    Hudson31 likes this.
  7. You don't need to hook up the lockup feature. The lockup is to save mileage and maybe a small amount of heat but unless you are pulling real hard like towing something the heat is minimal. I have been running one in my A for 2 seasons without the lockup and no problem. If it was a problem, then you would have to lock up the torque convertor in 3rd gear as well since most towing requires you to use 3rd gear not overdrive. If I did a lot of freeway driving I would hook it up. The speedo can be changed over to a gear drive but you must remove the tailshaft and remove the reluctor ring ( I think that is what you call it) and replace it with the proper size gear. Then you can put a mechanical speedo drive from an earlier 700R4 on it and you are good to go. I did it in a couple of hours.
    Hudson31 and lonestar395 like this.
  8. Schwanke Engines
    Schwanke Engines
    Lockup takes like 5 mins by putting a check ball in one place, but having a TV is a must for sure. You can change the speedo gear, but the shaft needs to be drilled and it's very hard.
    Sent from my XT1585 using The H.A.M.B. mobile app
  9. BLACKNRED
    BLACKNRED
    correct TV cable setup is critical, go to the bowtie chevy site
