Technical 700r4 question
Discussion in 'The Hokey Ass Message Board' started by LayinLed, Jul 7, 2014.
  1. LayinLed
    LayinLed
    from syracuse
    Finishing up re***embling my engine and am running in to a small problem. The bracket that retains the 700r4's TV cable will interfere with my existing accelerator bracket and linkage. My question is can I modify my bracket by shortening it for clearance without hurting my geometry. Any experienced advice or know how would be greatly appreciated.
  2. saltflats
    saltflats
    from Missouri
    If you are just moving the cable bracket and not the attachment point on the carb you should be ok.
  3. LayinLed
    LayinLed
    from syracuse
    Yeah I'm just shortening the bracket causing the cable retaining point to move forward. It will still be attached at its correct point on the carb.
  4. Hnstray
    Hnstray
    from Quincy, IL
    Seems to me your 'cable retaining point' has to remain the same distance from the carb as it was originally. Otherwise, I would think the cable travel would be affected, UNLESS the amount is so small that the cable housing adjustment is sufficient to compensate for the bracket movement.
  5. 48FordFanatic
    48FordFanatic
    from Maine
    You have to maintain the OEM length between the cable shield clamp at the carb and the connection point of the cable itself to the carb linkage. If you change this length you will have problems. Also , the distance the cable moves between idle and wide open throttle must also be the OEM distance , or again, you will have problems with shift points.
  6. LayinLed
    LayinLed
    from syracuse
    I have a telescopic adjustable TV cable I purchased from monster transmission if that makes any difference.
  7. oldsman41
    oldsman41
    go to bowtie overdrives and get some info great source.
  8. saltflats
    saltflats
    from Missouri
    You will be fine if you can still adjust the cable as needed.
    LayinLed likes this.
