700R4 Shifter Options
Discussion in 'The Hokey Ass Message Board' started by Thirtycoup, Dec 18, 2004.
  1. Thirtycoup
    Thirtycoup
    i'm getting ready to switch out the 5-speed for a 700R4 automatic and i was wondering what you guys use for a shifter? i want to install a tall homemade shift handle so the shifter can't have the push ****on. do they make such an animal? any suggestions? thanks, mike
  2. Gennie shifter. Contact Vaphead at Streamline. Look in the HAMBoDex
  3. Thirtycoup
    Thirtycoup
    thanks Tman, i appreciate it, mike
  4. Kiwi 4d
    Kiwi 4d
    Yes you can get the conversion where the shift knob pushes down , rather than a ****on. Just use a push bike brake cable outer as a detent pusher and cut to your desired length. Of scourge you will need to make your own length shifter but that's pretty easy with a heavy wall hollow stainless tube and grind a couple of slots in the top to locate the shift knob, for the up and down movement.
  5. Lad_RoadDevils
    Lad_RoadDevils
    B&M kit for trucks...
  6. X38
    X38
    Must be Back from the dead thread week!
