700R4 to chevy 235
Discussion in 'The Hokey Ass Message Board' started by rustypipes, Jan 21, 2005.
  1. rustypipes
    rustypipes
    from san jose
    have a 54 belair and am curious whats the pros and cons of putting a 700R4 behind the 235 with adapter kit. how difficult is this conversion anyone done it? any help is appreciated
  2. Bigcheese327
    Bigcheese327
    Pros... deeper first gear, overdrive fourth gear.
    Cons... having to change your rear end (not sure that's really a con), cost of the adaptor and drive shaft.
    Have I missed anything? Just make sure you hook it up to the old column shift, none of that B&M floorshift silliness.
  3. CLSSY56
    CLSSY56
    200-4r would be an easier swap, better gearing to boot.
  4. 38Chevy454
    38Chevy454
    Any of the adapter kits that work for a turbo350 or other GM trans will work for any 700R4 or 200R4. I second that you need a new rearend (open drive conversion), and the 200R4 is a better choice, it is smaller and will fit better.
  5. orange52
    orange52
    I've just started looking for an adaptor kit to do the same thing. The only one I've found so far is through Langdon's Stovebolt Engine Company. It runs about $350.
    Who else makes these adaptors?
  6. Hellbilly_Buzzard
    Hellbilly_Buzzard
    Saginaw 4 speed? That is what I am running.
  7. Goozgaz
    Goozgaz
  8. Kev Nemo
    Kev Nemo
    [ QUOTE ]
    [/ QUOTE ]
    no 4 on the floor? I was thinking a Mr. Gasket light truck kit with the crazy long stick ending in an 8ball! [​IMG]
  9. if its got a clutch, t-5 it.
  10. draggin ass
    draggin ass
    from hell
    the bellhousing is super different.... straight 6s in the 50s were rounded. i know this from experience.... doesnt bolt up at all.
  11. Rocket88
    Rocket88
  12. DrJ
    DrJ
    $350 will get ya a long ways into a running 250"-6 to replace the 235" and the 250" will bolt up to that trans.
  13. draggin ass
    draggin ass
    from hell
    just gave a 250 away. i have to agree with DrJ.
  14. Derek Mitchell
    Derek Mitchell
    I got a 292 I'll hook you up with for next to nuthin', with a power glide, too.
    The 292 will bolt strait up to the 200, 700 or whatever you want.
  15. Of course, attaching the 250/292 to the frame and clearing the radiator is a whole 'nother kettle of fish. By the time you change the mounts for one you coulda had a V8 for the same effort.
    I'm planning long term to T5 my '50 and run the 235 in it until it breaks. If it breaks, I'll go get a 261 -
  16. Try Advance Adapters.
