Technical 700R4 TRANSMISSION QUESTION
Discussion in 'The Hokey Ass Message Board' started by johnny jackson, Nov 11, 2023.
  1. johnny jackson
    johnny jackson
    Folks,
    In process of trying to figure out linkage to an old car with a newer transmission. So my first question is: Which way is Park on the 700R4 transmission linkage shaft....Left or right using the top as reference...?...see diagram.... trans.JPG
  2. '49 Ford Coupe
    '49 Ford Coupe
    You should be able to tell by the sound, when the internal detent throws in the lock gear into the rear drum... it will feel different from all the way the other way and sound different, too..
  3. vtwhead
    vtwhead
    Careful with the TV cable adjustment. Doesnt take much to fry a 700R if you are off just a whisker.
  4. '51 Norm
    '51 Norm
    from colorado
    When it is in park the output shaft is locked and you won't be able to turn it.
    rockable and chryslerfan55 like this.
  5. 19Eddy30
    19Eddy30
    from VA
    If you turn the wing / arm
    by hand ""P"" has a longer travel & a more Positive clunk sound , R N 4 321
    have a click sound & all the clicks are closer & short .
    Like mentioned make sure you adjust the ""Tv cable""
    correct , its very simple but
    "" Very Critical"" adjustment
    '49 Ford Coupe and chryslerfan55 like this.
  6. twenty8
    twenty8
    I think the selector shaft turns clockwise to engage park when viewed like the pic.
  7. RockyMtnWay
    RockyMtnWay
    HAMB advice can be scary at times.
    Here’s some visual hints.
    Remember that the forward position of shifter is usually Park.;););)
    twenty8 likes this.
  8. twenty8
    twenty8
  9. 1971BB427
    1971BB427
    from Oregon
    I've read this a lot, but not sure I believe it. I've even read people saying it can fry the trans in just a few miles. But I played with adjustment a lot when I set mine up to try to get the setting exactly where it should be and probably drove 5-10 miles during the process with no problems, and all is still OK 2 years later.
    '49 Ford Coupe likes this.
  10. deathrowdave
    deathrowdave
    from NKy
    They will fry the guts out of adjustment , but I think in will take a few more than 10 miles .
    gimpyshotrods likes this.
  11. '49 Ford Coupe
    '49 Ford Coupe
    You are correct. The "you will burn it up in one block" warning is an old wives tale.
    And/but the OP wasn't even asking about the TV cable. As far as the original question, I'm wondering why he even asked...a shifter kit (specific to a 700R4) will have instructions..
  12. saltflats
    saltflats
    from Missouri
    Lever will rotate clockwise to get to park.
    twenty8 likes this.
  13. johnny jackson
    johnny jackson
    Well, thanks guys. I ask because the vehicle I am using has a column shifter that is all hacked up and I couldn't tell which way was/is park. Right now, I have no shifter on it and need to start it. Don't want to start it in gear.
    So it looks like the answer is clockwise to Park? (from the view in my picture)
  14. I would ***ume you have a yoke or a driveshaft in the trans if you're gonna start the engine..***uming you put fluid in the trans. At that point, park shouldn't be hard to find..Yes?
    chicken likes this.
  15. johnny jackson
    johnny jackson
    Mark, yes. I got it. Thank you.
    pprather likes this.
  16. '29 Gizmo
    '29 Gizmo
    from UK
    Not all badly adjusted TV cables will fry a trans, but it is possible... and i have done it.
    The issue is free play where you get throttle travel without TV travel so valve pressure is too. If its badly adjusted the other way it will work but could give harsh shifts, which you may not even notice in a rod.
    You cannot garantee a correctly adjusted TV in anything other than the stock installation without pulling the pan on the trans and checking travel.
