Technical 700r4 transmission yoke
Discussion in 'The Hokey Ass Message Board' started by rustbucket54, Mar 15, 2016.
  1. rustbucket54
    rustbucket54
    Hey guys, I got a 54 chevy truck with a 700r4 ******. I am trying to determine witch yoke and universals I need. It seems there are several different options for length. This is a ground up build so I have no drive shaft yet. Guys at the trans shop seem to feel length is personal preferance.
  2. gimpyshotrods
    gimpyshotrods
    They are correct. It does not matter. You have your driveshaft made to fit it.
    I would choose a yoke designed to take the same u-joint that your rear axle takes.
  3. 29moonshine
    29moonshine
  4. 325w
    325w
    The local drive shaft guy can supply all yokes and u joints. Guy we use has a form for you to fill out. Answer the questions and he supplies you with a shaft that fits.
  5. El Gabacho
    El Gabacho
    Our drive shaft guy charges almost twice as much per ujoint that the our part store for the same brand........ouch
  6. gimpyshotrods
    gimpyshotrods
    How do you think they cover their overhead?
    Traditional?
