700r4 (which one's to avoid)
Discussion in 'The Hokey Ass Message Board' started by specialk, Mar 13, 2006.
  1. specialk
    specialk
    I have a line on a cheapie ($100-150) but IIRC, there is a cutoff point, prior to which a person does not want to buy them. Does anyone know that year?
  2. droplord49
    droplord49
    from Bryan, Tx
    I just had one built and the guy at the tranny shop said that the 88-92 is the one to get. Before 88 they weren't as beefy and after 92 they have a computer.
  3. burger
    burger
    Some of the later ones (there's no exact year cut-off) have a VSS plug instead of a mechanical speedometer drive. You can get the parts to switch it over from Bowtie Overdrives, but it'll set you back $70.
    Ed
    PS- Check out www.bowtieoverdrives.com
  4. Arizona Geezer
    Arizona Geezer
    yup, 88 up are the best ones.........but if you are buying it as a builder, have the tranny shop build it up for what you want.
  5. Kinky6
    Kinky6
    So, is there a number or code to I.D. the '88 thru '92 700R4?
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If the I.D. sticker is still visible on the case, it's a four character code like 8GTR or 9CTF. Get that, and a GM parts counterman can decipher it.
  7. Roddin28
    Roddin28
    very difficult to id it right --they changes some stuff in the tranny all 5 months till 84 - I have a 87 in my chevy but it was aut of "stronger" 5,7 camaro - so it was built stronger than the others and it is simular the 88 -- so I was told
  8. 286merc
    286merc
    from Pelham, NH
    Here is probably the best info on the Internet, Crosley is also a HAMBer as well as a tranny shop owner. He bailed me out on those trannies a few times including making a 700R4 work in place of a 4L60E in a 95 SS
    http://www.geocities.com/crosley_az/4l80e.htm
  9. Bruce Lancaster
    Bruce Lancaster
    If I remember correctly from an old magazine article, there is a visible difference between the good and bad periods...the earlies have several pressure test ports on the right side, later ones don't. Anyone here know iffen that's correct?
  10. specialk
    specialk
    Thanks to all, the crosley page was the best, it shows that the lack of pressure taps ID's the case as 89 onwards. $70 for the electro-speedo change isn't too bad.
    Who would you all recommend for a rebuild kit?
  11. specialk
    specialk
    btod does seem to know it all don't they :)
    And now they're selling their stage one for $850. Why rebuild?
