Technical 72 Ford 302 ignition questions
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Dec 13, 2025.
  1. Ron Brown
    Ron Brown
    Have a 72 Ford 302, basically stock with headers in a car that weighs about 2000 lbs with a 5 speed manual trans...picked up a used MSD distributor and coil...car runs great but feels a little sluggish, 35 deg all in on timing, no vac advance...thinking of installing the vacuum advance and with a car this light I was wondering what advance springs and stop should I use as a starting point...runs good, starts good but not as snappy as it should be...any help from the ford guys would be appreciated, and Merry Christmas to ya'll.
  2. squirrel
    what rear gearing does it have?
    What do you have for initial timing?
    When RPM is "all in"?
  3. RmK57
    RmK57
    I use the blue (light) and silver (light) springs with the 18 degree black bushing, which is the largest of them. Full advance at 2300 rpm. Initial timing on mine is 16 degrees.
    seb fontana and Toms Dogs like this.
  4. miker98038
    miker98038
    If it’s a stock 72, those were about the low point for the 302’s. What I remember (always doubtful) is a lower compression 2 barrel motor, really tuned down for emissions stuff. Doesn’t mean it can’t be tuned better, but there might be some upgrades in order. Depends what you’re looking for.
    Budget36 likes this.
  5. RmK57
    RmK57
    MSD has the information online, it’s just a matter of buying the spring/bushing kit and experimenting.
  6. Ron Brown
    Ron Brown
    3000 rpm
  7. Ron Brown
    Ron Brown
    the old distributor is a worn out Mallory that has issues...this engine is in a Sunbeam Tiger that originally had a 260 v8...has a 650 Holly and long tube headers...I do believe the MSD is factory settings, but will know more tomorrow when I pull the cap off...it does not currently have a vacuum advance but we are going to install the one that came with the dist.
  8. Mr48chev
    Going out on a limb here but a "used MSD" might not be much better or as good as a Known to be worn out Mallory. I used to work for the go to guy to set up distributors in Central Texas in the 70's and guys would show up with used Mallorys that they had bought off some dirt track racer that were plum worn out. Some times the same distributor that JT had told the racer that it was worn out. Simply meaning that a USED performance distributor is still a used distributor.
    Stilll I have fought the timing mark location thing on a couple of engines and would be brining that one up on TDC and checking to make sure that it is right. Simple things first then go to the complicated things.
    Side note, my Uncle sold Sunbeam Alpines in Cali in the 60's but I think he was down around Riverside at the time.
  9. Budget36
    Budget36
    I used to know a guy (lost touch with him 10/15 years ago) who had a Tiger with a stock 2bbl mid 70’s 302. That thing scooted along.
    I know you think it’s ignition related, but maybe investing in an O2 sensor set up and see what’s up with the AF ratio, might be in order and see what’s happening during the sluggish times.
  10. manyolcars
    manyolcars
    dont post any pictures. Moriarty told me not to talk about the 302 in my 1951 Ford
    finn likes this.
  11. Ron Brown
    Ron Brown
    LOL....dully noted
  12. Ron Brown
    Ron Brown
    yeah...checked TDC ( several times) and it is dead on...I think im gonna try to set it up all in at about 3000/3200 rpm...it acts sluggish, like it wants more advance so I may change to lighter springs...
  13. finn
    finn
    In that case, I guess the 350 Chevy should be off limits, too.
  14. Dave Mc
    Dave Mc
    you will need to match the distributor gear to the cam gear, most likely the MSD Distributor has a Billet Gear, while the 72 302 came with a Cast Iron Cam. mismatching the two doesn't end well.
  15. Oneball
    Oneball
    Do what @Kerrynzl said (Give it some more initial timing and see if it feels better)
    Kerrynzl likes this.
  16. 19Eddy30
    19Eddy30
    from VA
    Like other's have said more initial for starter's , then how fast timing avance ,
    Then total ..
    Then if you are serious
    Then you have points cam location or
    Stator , pic up , Pole in relation to rotor , adjustable rotor , rotor Phasing ,
    Weights, Advanced Limiters , custom
    Bushings that are not offered by Msd,
    wire's ,coil , gap between cap & rotor contact , spark plug , style , heat range ,
    Gap ,
    Even gasket thickness can change alignment and adjustments of all above.
    Just like carb , there is more then
    Jet change , squirter, squirter cam enrichment screws , Pv , fuel Volume versus pressure,
    There Air bleeds
    inertia tub & orifices
    Air filter , transfer slots ,
    Air inlet with velocity ,
    Intake & design ...
    Its really never ending when looking for
    Performance.
    One part can change every thing & process begins again..
    Tech book I believe No longer offered
  17. Before you get too far along, how about a compression test to see what the general condition of the engine is? There maybe be more to the story. However, I remember the 70's engines pretty much all being weak. :)
  18. RmK57
    RmK57
    Try the two light blue springs and the blue or purple bushing. Should be a safe start.
  19. seb fontana
    seb fontana
    from ct
    I have found in my stuff that once you get idle speed and mixture set the ign advancc so it starts advancing right off idle. This can be set up great with the Ford dist using ported vac advance.
  20. Ron Brown
    Ron Brown
    155 to 162 all cylinders...was the first thing I checked
  21. gas man
    gas man
    from socal
    I had a 72 302 in my 65 mustang. 72 isn't the best year but it still should feel pretty good. Are you sure your carburetor is opening fully when the pedal is pressed all the way down. Just helped a buddy the other day and he was never getting into the secondary.
  22. Does the exhaust sound right or flat? Sometimes retarded ignition will make an engine sound "sick". I doubt that is your problem. If you knew enough to check compression from the beginning, I'm thinking you have checked lots of stuff before posting. :)
