'74 vega 4 speed
Discussion in 'The Hokey Ass Message Board' started by emaleta, Jul 18, 2011.
  1. emaleta
    emaleta
    will a '74 vega 4 speed bolt in to my stock '56 chevy 283? Modifications?
  2. slammed
    slammed
    Hey introduce yourself. Now the trans. is a typical Saginaw, it should be a go. Not terribly strong, be gentle.
  3. hotroddon
    hotroddon
  4. mysteryman
    mysteryman
    from atlanta
    it should be a saginaw and should bolt write to your bellhousing
  5. ClayMart
    ClayMart
    I think you'll find that the Vega/Monza versions of this trans have no provision for attaching the shifter. In the GM H-bodies the shifter bolted to the floor pan instead of the trans extension housing. That said, the mounting bosses will likely still be cast into the housing but not drilled and tapped, and it might be pretty simple to do it yourself or have it done.
    Also, since these were used behind some fairly low powered engines, don't be surprised if you end up with a really low first gear. :eek: Not a bad transmission, but not built for countinuous thrashing.
  6. Rudebaker
    Rudebaker
    from Illinois
    The tail housing from a Saginaw 3 speed is a direct swap, they are more plentiful and most of the ones I have had had the shifter mounts. IIRC 1st gear on the Vega/Monza boxes is like 3.11 to 1.
  7. wannadrag
    wannadrag
    from WI
    The provisions for the shifter are there,just no threads tapped.
  8. RichFox
    RichFox
    I have a Hurst shifter on mine. No biggie
  9. 6-71
    6-71
    I used one behind a 350 in my 69 chevy pickup.I even used the vega shifter,bolted to the cab floor.I had to cut the shift lever off and turn it around to clear the bench seat. looked factory,and I even pulled a camper with it.:)
  10. I remember a Stock Car Racing magazine article talking manual transmissions, apparently some of these are stronger than you'd think, and you can ID the gears in it by rings on the input shaft. They were telling you for circle track racing you wanted the one with three rings, it had the tallest gears.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That would be a short with 3.50 first. I think what you mean is a wide ratio.
  12. B.A.KING
    B.A.KING
    been running one in my 59 elky for a bizillion miles. but thinkng about the 5 speed:D
  13. RichFox
    RichFox
    I kind of liked the stock shifter. Maybe I should put it back
  14. I have seen some Vegas that had an Opel transmission, I know that these have an integral shifter rather than one atached to the side of the trans, and if I remember right the Opel transmissions had the bellhousing one piece with the trans case. Avoid that one, but the Saginaw will bolt up to your bellhousing.
  15. emaleta
    emaleta
    Thanks for all the good info, I will have the original shifter and linkage and try to make work.
    Asa
  16. handyandy289
    handyandy289
    from Georgia
    Ran one for several years in a circle track car. Flogged it every lap. Used trans with a 2.20 second gear and 3.10 rear for a final of 6.90. Trans outlasted clutch and Be reasonable and you should not have any problems.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Every now and again on eb%# you'll find the mounting plate for the tail housings that have no holes. It uses the tailhousing bolts next to the side cover and attaches at the end with a U-bolt. It's a Hurst product.
  18. I put a vega ****** in a 55 chev back in 89 replaced a T10 it was great! 1rst gear was lower than the other trans and the car loved it still runnin strong .........the shifter bolts were tapped on the one I had.......... hurst shifter bolted right on
  19. lawman
    lawman
    Have "Flogged" mine for five years now. My 57 has a 355 SBC (2) 4s and a big Comp cam. Had no problem using the stock 57 chev V8 bell housing.
    I'm using a Hurst Comp+ shifter.
  20. emaleta
    emaleta
    will the drive shaft yoke splines be the same on the orig 3sp trans and the 74 vega 4 speed?
