Technical 8-10 IN. Crescent wrench
Discussion in 'The Hokey Ass Message Board' started by Paul, Sep 16, 2023.
  1. Paul
    Paul
    Editor
    my brother gave me this today as a birthday present, I'd never seen one before.. that I remember anyway.
    anybody else got a quirky old tool for show and tell?
  2. Kerrynzl
    Kerrynzl
    Metric and Imperial :D
  3. twenty8
    twenty8
    Left handed and right handed....
  4. atch
    atch
    20230916_231223.jpg Henry made all sorts of unique tools. There must have been a reason for this crooked crescent wrench.
    Sharpone, clem, Okie Pete and 10 others like this.
  5. Stogy
    Stogy
    Probably pretty darn old...any patent # @Paul?
    Sharpone, brady1929 and Tow Truck Tom like this.
  6. SS327
    SS327
    I had one like that until someone liked it better. It actually came in handy a few times. Mine was painted black from new.
  7. Stogy
    Stogy
    Adjustable with quick clamp and release feature...the jaws are also grooved for spring clamps or something similar...
    I found it on google patent...it had a Canadian origin...1919...
  8. Stogy
    Stogy
    This was given to me from a good friend he got it at a garage sale...it came from an WW11 era aircraft plant I worked in...the jaws move straight up and down...clamp leverage is perhaps more robust than typical pliers...it also has a cutting feature...though not an adjustable it is a pretty odd duck...US in origin...
    AVRO was around from about 1940 something till 1959 or 60ish in Malton, Ontario, Canada...
    Lancasters, Ansons, Jetliner, CF100, CF105 Arrow, Avrocar were just some of what went on there in the Hamb era...
    https://en.wikipedia.org/wiki/Avro_Canada
    Was it used on aircraft or maintenance...not sure but the straight close and grip jaws would work well on flat aluminum and related materials...
    http://alloy-artifacts.org/wm-schollhorn-company.html
    :rolleyes:...why the internet is cool...
    The pair I have is newer but this company has roots...again it may have found a repurpose to aviation...
  9. Fortunateson
    Fortunateson
    That's not a Crescent wrench it's a Keystone...
  10. Harv
    Harv
    from Sydney
    One end is for hammering on stuck starter solenoids, the other for hammering on bolts to start them (cross threaded).
    Cheers,
    Harv
  11. Ironworkers tool... at least I've seen a few old timers with one.
    Okie Pete, Stogy and lothiandon1940 like this.
  12. Kerrynzl
    Kerrynzl
    If your starter is made by Lucas , you need this "High End" British specialty tool to hammer it :D
  13. Stogy
    Stogy
    Crescent 8-10 Inch Double Adjustable Wrench
    We'll begin with an early double-ended wrench, a once common tool that's now regarded as a novelty.
    Fig. 10. Crescent 8-10 Inch Double Adjustable Wrench, with Insets for Side View and Back Side Detail.
    Fig. 10 shows an early Crescent 8-10 inch double-ended adjustable wrench, marked "Crescent Tool Co." and "Jamestown, N.Y." in forged raised letters, with "Crescent" and "Drop Forged Steel" on the back side.
    The overall length is 10.1 inches, and the maximum jaw openings were measured at 1.0 and 1.1 inches for the 8 and 10 inch ends, respectively. The finish is polished steel.
    The head thickness was measured at 0.58 and 0.73 inches for the 8 and 10 inch ends, respectively.
    This wrench has an additional "Patented" marking forged into the shank, and this is believed to be a reference to patent #1,133,236, issued to K. Peterson in 1915. The patent describes the use of a tension spring to help hold the adjusting screw in position.
    http://alloy-artifacts.org/crescent-tool.html
  14. X38
    X38
    Yeah, those adjustables are called shifting spanners here. Well, shifters. I guess because the jaw position shifts. Shifter is all I've ever known them as. In the U.S. Cresent became the generic name. Like how English people 'hoover' the floor with any brand vacuum cleaner.
  15. HOTRODPRIMER
    HOTRODPRIMER
    Rarely seen metric & standard Crescent wrenches. HRP
    clem, Jokester, alchemy and 30 others like this.
  16. Stogy
    Stogy
  17. Stogy
    Stogy
    Kinda like vise grips...one size fits all...metric or sae...but both are not true...I first thought Paul's wrench was crazy but the heads have different ranges...less trips to the tool box...and the fact they're close means if one doesn't fit the other will...clever stuff going on...Dad creating the tool design and the young hoodlums using the tools to wrench them Hotrod/Customs...:D
  18. Rex_A_Lott
    Rex_A_Lott
    This one is marked Fordson which was , of course, a tractor. Ive never seen one with an adjustable head, but I have seen some half round ones with a regular box end that were said to be for alternators and generators. Thanks for the pic.
    Okie Pete and Stogy like this.
  19. I had one of these parallel pliers in my aircraft maintenance toolbox when I did my apprenticeship about 45 years ago, used them for about 25 years, and then they broke. Not overloaded or mistreated, the jaw just cracked off. Never seen one since.
    The shifter is also called the AFS spanner here, Any Flippin' Size.
    I have a strange shifter which has the moveable thread cut opposite to all the others, it opens when you turn the screw in the "closing" direction of the others.
    down-the-road, Okie Pete and Stogy like this.
  20. Kerrynzl
    Kerrynzl
    The Crescent wrench is also known as a "Portable Lathe"
  21. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    That makes complete sense.
    No handy tool box.
    No workbench to put things.
    A desire to use one hand for steady, while one hand pulls on the wrench.
    And 12 stories up and away from Mother Earth
  22. Jack E/NJ
    Jack E/NJ
    from NJ
    6-inch jaw of mine busted off. Guess they don't make 'em like they used to.
  23. mitch 36
    mitch 36
    View attachment 5844748 The 8-10 I got from probably my GranPa is an early DIAMOND CALK HORSESHOE COMPANY Duluth, Minnesota . USA. Mitch 20230917_071618.jpg 20230917_071609.jpg 20230917_071530.jpg
  24. Moriarity
    Moriarity
    SUPER MODERATOR
  25. 41 GMC K-18
    41 GMC K-18
    These are a vintage pair of (Klein) lineman's pliers, they were my grandfathers, they still are very accurate.
    Built to last a lifetime !
    My grandfather used old green garden hose, to cover the handles.
  26. HOTRODPRIMER
    HOTRODPRIMER
    The Crescent wrench is a versable tool also. HRP
  27. Marty Strode
    Marty Strode
    And a micrometer as well.
    alanp561, ClayMart, Stogy and 2 others like this.
  28. krylon32
    krylon32
    from Nebraska
    Just checked, several double ended Crescent wrenches on E-Bay, Pricey.
    Stogy likes this.
  29. krgdowdall
    krgdowdall
    from Alberta
    [​IMG]Miners wrench still available new
    Since everyone uses it for a hammer the hammer head is built in. The round end is broached as a 7/8 box end wrench. I believe this was built for underground miners working on the tracks.
