Technical 8.8 Rear End for a Hotrod Info
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Aug 21, 2020.
  1. panhead_pete
    panhead_pete
    Thanks GreaseMonkey just edited the post to reflect the tag info.
    greasemonkey54 likes this.
  2. If I get a Ford in the shop tomorrow I'll photograph the tag for a visual explanation
    panhead_pete likes this.
  3. LWEL9226
    LWEL9226
    from So. Oregon
    We put one in a '56 Parklane wagon....
    Shortened the long side 2 7/8 to short side dim.... Fit very well... no tunnel issues at all...
    LynnW
  4. Rusty J
    Rusty J
    I'm running an 8.8 under my 39 chevy sedan - the one in my picture, and mustang 2 front suspension - yes I know it's forbidden, but that's what it is. Glad to see some good info here. I'm in the process of modifying the wheel wells to fit the wide tires - this is fun. Oh, and a Chevy running on Ford suspension - what alternate universe is this?? :)
    coast40 and Okie Pete like this.
  5. 51504bat
    51504bat
    Put a non Hemi in it and really see the vortex shift.:cool:
  6. typo41
    typo41
    That will cause a rip in the Space Time Continuum
  7. panhead_pete
    panhead_pete
    Have updated the original thread, as I find new relevant info will continue to do that so its all in one place. Thanks to all that are contributing. Got to love the HAMB.
  8. panhead_pete
    panhead_pete
  9. 1971BB427
    1971BB427
    from Oregon
  10. jimmy six
    jimmy six
    As for being traditional. The “look” of an 8.8 is nearly the same are early T-Birds, Ford wagons and pickups.. good enough for me.
  11. coast40
    coast40
    I have an Exploder rear on hand to replace the DANA 53 in my 40, if necessary.
  12. blue 49
    blue 49
    from Iowa
    If using junkyard parts make something more traditional, a rear cover from an Explorer with IRS can be made to look pretty good. Just trim the ch***is mounts off.
    Gary
    winduptoy, brEad, Uncle Ronn and 5 others like this.
  13. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Are those "fill" and "drain" plugs functional ? You did a nice job modifying it.
  14. blue 49
    blue 49
    from Iowa
    Both plugs are real. The big drain may be for ring gear inspection, too. I don't know why else it would be that size. Also, it doesn't leak like the chinese chrome one I had on before.
    Gary
  15. panhead_pete
    panhead_pete
    Thanks Gary. What are those `straps` you used to hold the brake lines down?
  16. blue 49
    blue 49
    from Iowa
    Just worm gear hose clamps. I opened my vise to about 1/4" and pounded a radius into them to fit the brake lines.
    Gary
  17. Do all 8.8 Ford axles have the pinion offset? I was considering a Ranger 8.8 for my 1950 Chevy 3100, but I haven’t started on it yet and I’m unsure if the offset will be a problem.
  18. panhead_pete
    panhead_pete
    Thanks Gary
  19. 6sally6
    6sally6
    I would love to see pictures of your Foul-**** !!
    Since my early years with a 64 Sprint..........I have kept a soft spot for them....
    thanx
    6sally6
  20. blue 49
    blue 49
    from Iowa
    Mine, in my Henry J, is from an '03 Ranger with the offset. It's not a problem if it clears the driveshaft tunnel. Shouldn't be a problem in a truck.
    Gary
  21. brEad
    brEad
  22. tjm73
    tjm73
    This is an old post but I wanted to correct this info for future searchers. 1996 was the last year for the 5x5.5 bolt pattern "boxy" body style. All were drum brake. 11" x 2.5" if I recall correctly. In 1997 the F150 went much more aero. It also changed to 5x135mm (5x5.315") bolt pattern and with it came disc brakes that require 16" or larger wheels.
    Edit: extra info....the 97+ 5 lug trucks still had drum brakes in lower trim levels with the smaller engines.
    Edit 2: In researching the disc brakes question more I've come to believe that the 8.8 used in 97-up trucks never got disc brakes. I believe, until I know differently, that if the 97-up truck has disc brakes it has a 9.75 Sterling axle. I don't believe that any 97-up 8.8 ever left Ford with disc brakes and the truck 5x135 bolt pattern.
