Hot Rods 8" Axle Question.....
Discussion in 'The Hokey Ass Message Board' started by Skimmer, Dec 2, 2022.
  1. Skimmer
    Skimmer
    Ive been offered an empty 8" Ford axle casing , its 52" flange to flang so can anyone tell me with the brakes etc fitted what will be its total lenght hub to hub of brakes be ........asking as dont want to be chasing bits down then discover it doesnt fit ..Thanks
  2. Kevin Ardinger
    Kevin Ardinger
    If you figure the brakes are 2” wide and the axles just clear them by about an inch add about 3 to 3 1/2 inches to each side roughly. I think???
  3. bchctybob
    bchctybob
    Add about 2.5" per side for the standard brake ***emblies. A lot of 8" rear ends were about 56 1/2" from wheel mounting surface to wheel mounting surface.
    Edit; make that about 2 5/8" per side allowing some running clearance between the backing plate and the drum.
    Skimmer and Just.dale like this.
  4. Just.dale
    Just.dale
    Should be 57 1/4, 65 mustang???
    Skimmer likes this.
  5. bchctybob
    bchctybob
    That's what the math says with his housing. The one currently under my '33 pickup tapes out at 56 1/2". Don't know what car it came from or why the slight differences. But hey, 56.5-57" is a good width for early Fords, better than 60-63".
    Just.dale and Skimmer like this.
  6. Skimmer
    Skimmer
    Looks like the casing could be perfect as i need 57 1/2" hub to hub brake faces , its for my 32 Sedan , Thanks for the replys
    Just.dale likes this.
  7. Just.dale
    Just.dale
    56-1/2 was Maverick, have one in my 36.
    RICH B, gimpyshotrods and bchctybob like this.
  8. gimpyshotrods
    gimpyshotrods
    If fuzzy memory serves, the 8-inch found in the Mustangs of that era had stepped tubes, that were smaller in diameter towards the brakes, and a Maverick 8-inch did not.
    I, of course, could be totally wrong.
  9. RICH B
    RICH B
    52" flange to flange would be a Maverick which would be 56-1/2" at the wheel mount surface.
    Probably be better off finding a complete axle vs having to hunt down a pair of axles and backing plates along with a center section.
  10. twenty8
    twenty8
    Always more expensive to buy all the bits separately.........
  11. gimpyshotrods
    gimpyshotrods
    He's across the pond, too. Not sure about what is laying about out that way.
  12. I think @gimpyshotrods is correct (as usual), the early Mustang rear had a stepped down tube mostly. I have a 68 Cougar rear that is slightly wider than the 56.5" Maverick rears I also have. I will measure both and get back to you.
  13. Part 2- Maverick rear measures 52" flange to flange (Cougar rear 55"), so most likely it is Maverick rear that is 56.5" WMS to WMS. Ford used two different rears in the Maverick. The early cars (up to 74), had either a 5 lug axle with a straight tube, or a 4 lug axle with a stepped tube. The wheel register also changed in 74, from 2-3/8" to 2-3/4". The later Mavericks (74 up) all had straight tube axles with 5 lugs, and 10 x 2" brakes, except the Grabber which was 2.5" if memory serves. Pictures of the housing would help.
  14. BamaMav
    BamaMav
    from Berry, AL
    Stepped tube was 4 lug axles, they had smaller bearings than 5 lug. You would have to retube to use with 5 lug axles. Best I remember, all had 2” x10” brakes. Maverick Grabber was only a appearance package, no different underneath than any other Maverick.
    2OLD2FAST likes this.
  15. 42merc
    42merc
    Not so.
    Early V8 Mustangs had a stepped tube & 5 lug axles.
    2Blue2 and gimpyshotrods like this.
  16. RICH B
    RICH B
    Maybe there were other options but all the Maverick, Mustang, and Fairlane 8" rears that I have come across or used have all had 10" x 1-3/4" rear brakes.
  17. krylon32
    krylon32
    from Nebraska
    I have a 56.5 Maverick rear under my 40 coupe on a CE parallel rear spring kit. Bolt in, works great.
  18. bchctybob
    bchctybob
    I used a Maverick 8” in my ‘27 T. I pulled it from the car during our Pick-a-Part half price weekend, $40. I had heard that the V8 Mustang IIs had better ratios and sometimes a limited slip. Sure enough, I found two “posis”, both with 3 something gears, much better than the 2 something gears in the Maverick, and both half off. Good day at the junkyard.
    38Chevy454 and 2Blue2 like this.
  19. gimpyshotrods
    gimpyshotrods
    If axle housing appearance is not an issue, the 7.5 and 8.8 inch rear ends from the Ford Ranger pickup, from 1990 to 1992, are 56-1/2" wide.
    It has 9" or 10" brakes, depending on a presumably undisclosed formula.
    I have seen all combinations.
    It does have some pinion offset. If that is not a problem, it could be a candidate.
    Hnstray and bchctybob like this.
  20. goldmountain
    goldmountain
    Since you are located way over there, why not look into Volvo rear ends?
  21. Skimmer
    Skimmer
    Id love to find a complete axle but here in the U.K. there thin on the ground andhard to find ....
  22. Skimmer
    Skimmer
    They have funny stud patterns and really hard to get wheels that match anything period ...
  23. goldmountain
    goldmountain
    It would be relatively easy to redrill to another bolt pattern. A long time ago, a friend put a Volvo rear axle ***embly in his old coupe and I think it was 4 1/2" on 5 pattern.
    Algoma56 likes this.
  24. fastcar1953
    fastcar1953
