Projects 8" Ford Bargain !
Discussion in 'The Hokey Ass Message Board' started by Blue One, Aug 25, 2011.
  1. Blue One
    Blue One
    from Alberta
    The Maverick is the narrowest Ford rear axle at 56.5 ".
    The 65 Falcon is 58 ".
    There is a good chart here.
    http://www.carnut.com/specs/rear.html
    The Mavericks with a 302 have the good 5 lug axles. Looks like I may now have a spare for another project down the road :)
  2. Blue One
    Blue One
    from Alberta
    Confirmed, another Maverick rear :)
    So, the only thing I'll have to do is rebuild the brakes.
    Gotta love it. Then all the components in my rear will get transferred to the housing and I have another complete rear which of course would need a rebuild. A spare.
  3. BrokeDick
    BrokeDick
    from Idaho
    Is that a waffle case on that 8 inch ?
  4. Blue One
    Blue One
    from Alberta
    Waffle case ? Like eggo waffles ? :D
  5. K13
    K13
    Did you find brake parts easily for yours? I have to get everything.
  6. Blue One
    Blue One
    from Alberta
    Have not tried yet, I am hoping that I can get a complete hardware kit to replace all the bits and pieces, springs etc. along with the shoes, wheel cylinders and all.
    New drums too.
  7. K13
    K13
    Let me know if you find it and where as I need the same.
  8. Andy
    Andy
    You can check for warpage by turning the housing with everything ***embled, including tires. Block the tires and use a dial indicator on the side top of the tires. If you get movement, the rear is warped. Put heat opposite from where it was welded and try again. Works great. If you can roll the housing and the tires stay still, the rear is straight.
