8" Ford rear years and changes
Discussion in 'The Hokey Ass Message Board' started by blowby, Mar 5, 2013.
  1. blowby
    blowby
    from Nicasio Ca
    I have an 8" Ford of unknown vintage and 3:00 gears. I'd like something in the 3:50 to 4:00 range. What are my chances of finding a pumpkin in the boneyard and what years and models would give me the best shot? Do they all interchange?
  2. lowkroozer
    lowkroozer
    I can't tell you the year but the 8'' has a 3.42 ratio ring and pinion available.from Summit
  3. 38Chevy454
    38Chevy454
    I think 3.55 is the lowest factory ratio you can find and those are scarce. Pinto or Must II are some donors I have heard. Lower than that and you have to go aftermarket. I know factory had 3.25, 3.00 and 2.80 ratios as well.
  4. go-twichy
    go-twichy
    i got a posi unit from a v8 mavrick grabber. i cant recall the ratio though.
  5. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
  6. V8 Bob
    V8 Bob
    During the '60s, the 8" was used on most 260-302 V8 equipped vehicles, (exceptions were the HiPos/Shelbys) and had available low ratios of 3:55, 3:80, 4:11, and lower, usually found in Mustangs, Fairlanes, etc. (I have a '66 Mustang 8" with a 3:80). Ford never, to my knowledge, used the 8" with any vehicle engines larger than 302, so your best bet is '63 to '68 small V8 Fords for the low factory ratios.
  7. finn
    finn
    I disagree with this: Almost all small Fords with the 8" were in the 2.75-3.00:1 range with a smattering on 3.25 and occasional~3.50.
    The HIPO cars and Broncos where one would find steeper gears all had 9" rears.
    Remember these were light cars with no overdrive and Ford did not push steep gears or limited slip differentials like GM did. A 66 Mustang factory equipped with an 8" and 3.80:1 gear would be a rare find.
  8. TurboX2
    TurboX2
  9. Do Good Jr.
    Do Good Jr.
    from texas
    I have a 68 Mustang. With an 8" that I built years ago. It had 2.79 gears and I changed them to 4.11's that I bought from Jegs.
    Sent from my DROID device using the TJJ mobile app
  10. sidevalve8ba
    sidevalve8ba
    Ages ago I had an 8" center section with 3.40 gears. i know because I counted the teeth about 3 or 4 times. I may well have been aftermarket gears. I bought the centersection used and that is what came in it.
