I'm trying to track down a source for 8 inch Ford shim kits and crush sleeves... anybody out there know of a supplier??? I can find lotsa stuff for the 9 inch but nothin' for the 8 .
heres where we go- Hoopers Rear End 12201 Branford Ave. Sun Valley, CA 91352 US phone: (818) 899-2515 fax: (818) 897-0952
Ratech lists 2102 as pinion shims 3101 for crush sleeve 131K for basic install kit (all shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, and gasket.)
I've orderd 8in stuff from Summit, and if you got a Keystone dealer in the area, they can also get you everything you need....
