8 point screw head - what is it?
Discussion in 'The Hokey Ass Message Board' started by GregCon, Dec 16, 2012.
  1. GregCon
    GregCon
    from Houston
    This is the cruise control servo out of my '58 Chrysler, which is the first car offered with cruise. It is made by Perfect Circle.
    Does anyone recognize this screw head? Better yet, does anyone know who sells sockets that fit it? It is about 9/32" diameter.
  2. 325w
    325w
    Will nota 12 point fit it?
  3. 62RagtopNova
    62RagtopNova
  4. 3Kidsnotime
    3Kidsnotime
    from Utah
    Years ago 8 point sockets would come with a craftsman tool kit they work great for pipe plugs.. Most that got a set threw them away...
  5. nathan289
    nathan289
    from spokane,wa
    Try an e socket most auto parts stores will have them.
  6. GregCon
    GregCon
    from Houston
    No, a 12 point does not fit. Or if it did I would need something like a 17/64" socket which I have never seen. Note how rounded the corners are, too. An 8 point socket might fit, maybe but again I have never seen one of that size.
  7. GregCon
    GregCon
    from Houston
    E sockets (external Torx) are 6 point, won't fit. I also can't find anyone who sells external Torx 8 point sockets.
  8. Kustom292
    Kustom292
    from Winnipeg
    That is one of the stupid manufacturer security fasterners. you need to either make a tool or get one from the manufactuere or dealer.
  9. clean cut creations
    clean cut creations
  10. nathan289
    nathan289
    from spokane,wa
    How about those new craftsman snake oil wrenches and sockets with the square teeth.
  11. Crystal Blue
    Crystal Blue
  12. Crystal Blue
    Crystal Blue
  13. GregCon
    GregCon
    from Houston
    I ordered earlier today some of the 8 point sockets from McMaster, but I am not at all convinced they are correct. They might work...but if you look at the rounded-ness of the screw head they are clearly not a 'normal' 8 point configuration.
  14. hotroddon
    hotroddon
    Those are known as an 8 point star, just search for 8 point sockets, they are still available, if not common
    E Sockets don't fit - they are 6 point.
  15. GregCon
    GregCon
    from Houston
    Nope, they are not star design. Look at the rounded valleys and rounded points.
  16. hippy killer
    hippy killer
    not a torx but i have seen them on 80s bmw's snap-on make wrenches ect. for them
    they piss me off
  17. GregCon
    GregCon
    from Houston
    No it is not a Torx....8 points versus 6. While I have found reference to 8 point Torx, I have yet to actually see any screws or sockets that are 8 point.
  18. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Looks like an eroded spline fastener.. used a lot in the aviation field.. Snap-on and others do make sockets and wrenches..
  19. cornbinder52
    cornbinder52
    How about one of those gator grip sockets with the pins in them? Dad got one for Christmas a few years back, not sure if they work.
  20. 3Kidsnotime
    3Kidsnotime
    from Utah
    Thinking about this, and also being the first marketed part of its kind, good chance it was a MFG specific socket head.
  21. thorpe31
    thorpe31
    from nor-cal
    or double square
  22. Don's Hot Rods
    Don's Hot Rods
    from florida
  23. henry29
    henry29
    It looks like an adjustable wrench might work.
  24. Piewagn
    Piewagn
    Kobalt makes a set that will fit that bolt, you can get it at Lowes!
  25. HamD
    HamD
    Have you tried asking for a double-square bit anywhere? Sunex makes larger ones in metric.
    Two alternate solutions come to mind. The drive side of an OTC 7807 socket is 3/8" and has double-patterns. If there's something like that in 1/4" drive, it might work, albeit not in a pretty way but I bet you could vice-grip something like that and make it work.
    Then, if you had a piece of steel stock drilled through the middle and you ground out 8 grooves, you could probably finagle something to work.
  26. Country Gent
    Country Gent
    If the Lowes set don't work try one of those new fangeled socket sets on the market that grips any rounded or wore down head.
  27. Grind a slot in it with a cutoff wheel and use a screwdriver...
  28. HamD
    HamD
    Snapon F308, F310, BLPS814516, BLPS8141 and Craftsman 44341 & 44342, but you probably have those sizes covered w/ the mcmaster stuff you ordered.
  29. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've always had good luck in situations like this by taking a socket that is close but slightly smaller and tapping it tightly over the head so it jams onto the bolt. Then you can unscrew it while keeping downward pressure on it. Being that the head is 9/32 that is just slightly bigger than 1/4 so maybe that size or a similar metric will work.
    I have a bunch of 8 point sockets that I keep just for goofy stuff like this and although I don't use them every day they do get me out of a jam now and then.
    Don
  30. i guess it would come down to weather you want save it or just get it out?
    for the latter ? just pound a nut on it and fill it with weld and back it out with a standard ..... lol
