Hello folk Well as some of you know,my coe is on a 1982 Chevrolet C20 ch***is. When I aquired the truck i didnt notice how the front tires were aligned.. I installed aftermarket dropped spindles and now i noticed the tires sit outward on the bottom. Maybe its a visual thing? does anyone in the group jnow where to look into?
Lining my eyeball up with the shop door opening, it does look out at the bottom. Has someone cut the springs, or had the suspension apart and not re-aligned? Rule of thumb: Inner and outer pivots on the lower A arm should be equal distance from the ground. (or close)
