Projects 8ba cylinder head questions
Discussion in 'The Hokey Ass Message Board' started by CJ95, Oct 27, 2025.
  1. CJ95
    CJ95
    I am rebuilding an 8ba for my 31 ford. As I look at heads there's a lot to look at now and everyone points the finger at Navarro for being the best but they are much more expensive. Now I am not trying to cheap out here but I also hear offy heads are very nice bit dont quite make the power Navarros do. Is the couple extra hp worth the couple hundred bucks? Or is it quite a bit more power?
  2. Hitchhiker
    Hitchhiker
    If you're worried about a few hundred bucks on a flathead, you're probably in the offy camp
  3. CJ95
    CJ95
    I am definitely not worried. I know flattys come in horsepower per cubic dollar. But I just wondered if the performance gain was rather large or not very.
  4. tubman
    tubman
    In my book, Edmunds heads are the best. They have the spark plug relocated just enough so that it is no longer right above the exhaust valve. This allows the use of extended tip plugs that gets the spark further out in the combustion chamber for maximum efficiency. I am running two pair and couldn't be happier. Of course, since they are no longer made, you have to look a bit to find a good set. They are out there.
    No matter what brand you decide to use, make sure you fit them to your engine to optimize quench. In my book, it is the one thing that adds the most efficiency to a flathead.
    rmcroadster, jet996 and CJ95 like this.
  5. 19Eddy30
    19Eddy30
    from VA
    Just Saying , Think out Side the
    box / Norm ,
    Relocate Plug , by making a plug for Original location , Then New plug hole
    Or even Twin Plugs !
    also some where here on HAMB
    Some have issues with a **** crank
    If thats case & wanting to build a big inch
    F -H why not have crank made
    $1,500-2k
    CJ95 likes this.
  6. Bandit Billy
    Bandit Billy
    I run the blower heads from Navarro on my 8BA, but they required a little work before installation. They weren't flat on the bottom which wasn't a big deal since we had to deck them to dial in the quench as @tubman mentioned. They also had to be milled at all of the mounting holes so the washers and acorns would sit flat. That could have been a polishing error as I purchased them polished from H&H.
    Flat48 and CJ95 like this.
  7. CJ95
    CJ95
    I actually have a factory merc crank lucky enough.
  8. CJ95
    CJ95
    I have heard castings on any of this stuff isn't what it used to be
    Bandit Billy likes this.
  9. ronnieroadster
    ronnieroadster
    Actually the HP difference between Navarro of Offy heads is so little you would never actually feel it.
    Ronnieroadster
    Toms Dogs, Ziggster, warbird1 and 4 others like this.
  10. CJ95
    CJ95
    Thats kinda what I wondered. Especially in a middle of the road street build
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    Save your money. You’ll never notice the difference. It’s all about looks and sound a few hp isn’t worth it
    Ziggster and CJ95 like this.
  12. Bandit Billy
    Bandit Billy
    Polished, ribbed aluminum overhead valve covers don't even add a few HP, yet...:cool:
    CJ95, lostn51 and jet996 like this.
  13. big duece
    big duece
    from kansas
    The Corvette ones do...
    CJ95 and jet996 like this.
  14. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    According to Joe Abbin, flathead extraordinaire from Albuquerque, there is less than 3-5 h.p. Difference between the best flowing head(has a flow bench and dyno and knows how to use them) and Henry Ford cast iron. In other words, there has not been a head designed that will appreciably increase the horsepower over a stock cast iron head. The finned aluminum look is basically for looks and very little increase in power. Spend your monies on displacement,more carburetor,porting, and valve sizes!!! IMG_1064.jpeg
    GuyW, Ziggster, CJ95 and 3 others like this.
  15. 51504bat
    51504bat
    Maybe just a set of EAB heads and call it a day?
  16. Model A Gomez
    Model A Gomez
    I'm running a 8BA with early heads because I wanted the center outlets, Offenhauser 400 heads, Offenhauser intake with 2 Holley 94's, H&H flathead with a 3/4 cam in a 30 Sport Coupe and it has plenty of power. I'm really impressed with the workmanship from H&H, but you definitely pay for a flathead. Been driving my coupe about 5 years and it's close to a $6K flathead so be a lot more now.
    GuyW, RMcCulley, Bandit Billy and 2 others like this.
  17. CJ95
    CJ95
    Thats kinda what I have gathered. Flatheads are a trip. They take all the engine knowledge you have garnered over the years and all but throw it out haha. Its still a air pump more air more power but compression has an adverse affect
  18. Ziggster
    Ziggster
    I wanted a nice dual carb intake and fancy aluminum heads, but looking at the price, then converting that to CAN$, it just didn’t make sense, and this was just before Covid. So, for now, stuck with an earlier Ford aluminum intake and stk cast iron heads. I did just splurge on a vintage 2x2 Edmunds intake at Hershey this year ($400). Also, the second C59A flathead I “rescued” has the factory Ford aluminum heads, so might swap them out one day, or keep them if I rebuild it.
  19. Bandit Billy
    Bandit Billy
    Dude, your in Canadia, a set of aluminum ford heads and polish the **** out of them. I love those things! They would look tidy with a polished Edmonds intake.
    Ziggster, CJ95 and Hotrodmyk like this.
  20. Bandit Billy
    Bandit Billy
    That's a flathead hot rod! Money well spent my son!
    CJ95 likes this.
  21. dan c
    dan c
    ever see the "hot rod" magazine series from 1956, "building a flathead the right way"? their suggestion was to use iron heads. less problem with erosion and expansion rates are the same as the block. of course, they don't look as good...
    GuyW, 51504bat and CJ95 like this.
  22. CJ95
    CJ95
    True. Aluminum heads add at least 1000 visual HP
    dan c likes this.
  23. 19Eddy30
    19Eddy30
    from VA
    If cast Iron heads used,
    Be creative Mill / Ball Mill
    Rib's /Fin's in heads
  24. CJ95
    CJ95
  25. CJ95
    CJ95
    Looking at picking these up
    Ziggster likes this.
  26. Ziggster
    Ziggster
    One of the best sounding flatheads out there. This vid pretty much cemented my decision. to go with a flathead. Had Sharp heads and Sharp intake.
    CJ95 likes this.
  27. CJ95
    CJ95
    That does sound fantastic. My only worry is whatever that 9.5 stands for thats stamped in. Hopefully thats not compression ratio. That would be crazy high
  28. Jeff34
    Jeff34
    I had some similar Sharp heads that were stamped "MOON" and "10.0". I ***umed that it was compression ratio, but not sure.
  29. CJ95
    CJ95
    I would guess the only way is to cc them and do the math. There is not much info out there on vintage sharp parts
  30. CJ95
    CJ95
    He called back with valve relief clearance... oh yea high high compression. No go for me
