Technical 8BA Flathead Cams shaft advice
Discussion in 'The Hokey Ass Message Board' started by Ben Hall, Aug 2, 2017.
  1. Ben Hall
    Ben Hall
    from Adelaide
    Hi,
    Currently putting a Flathead 8BA together with the following parts.
    Edelbrock Heads 4.125 Stroke Crank, Small Weiland Supercharger.
    It is going in a 1927 Ford T.
    Was thinking a ISKY 88 Camshaft. The owner is only using it for street use.
    Thank you in advance.
  2. deucemac
    deucemac
    Call Jerry Cantrell at Schneider Cams. He will custom grind a cam that will work perfectly in your application. I've been using his cams since the 60's and never a complaint. I have several flathead engines with varied combinations all running custom ground cams from Schneider and all my customers love how they work. Call and talk to him, but don't use any cam because you just happened to have it . (619) 297-0227 . Even if you don't use him, you will learn lots about cam selection.
