Technical 8ba main bearings
Discussion in 'The Hokey Ass Message Board' started by Matthew Davis, Oct 17, 2024.
  1. Matthew Davis
    Matthew Davis
    does anybody know of anyone that makes a set of main bearings that are 050 under? i have a merc crank thats coming up .050 under and hoping i dont just have a paperweight. thanks
  2. Matthew Davis
    Matthew Davis
  3. FrozenMerc
    FrozenMerc
    I am not seeing anything currently available beyond 0.030" Under. Maybe some old NOS parts out there at 0.050"
  4. swifty
    swifty
    Sounds like you need to get your crank journals metal sprayed and re-ground but with the high rate per hour on stuff nowadays it will probably be cheaper to find another crank or buy a new **** one.
  5. tubman
    tubman
    At .050" under would there be any surface hardness left? There's probably a good reason those bearings aren't out there.
    EDIT : Found this with Google :
    "The most common depth is in the range 0.020”-0.030”. Importantly, the process results in increased hardness on the outside of the material; however, the low carbon core remains relatively soft. The outside is very hard but very brittle; however, the inside is soft and ductile."
    And this :
    "The depth of hardness is dependent upon the time the crankshaft is exposed to the gas. Typically, a nitrided crankshaft will have a hardness depth of about . 010 - . 030."
    You're lucky they don't make 'em.
    F-ONE likes this.
  6. seb fontana
    seb fontana
    from ct
    Montgomery-Ward had ground cranks .040, don't remember if down to .050. I know in the early 60's you could get piston rings individual, wrist pins .001 over, valves with o/size stems, etc. Bottom line is have to find someone with really old NOS.
  7. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Try Baxter Ford in Kansas/they “used” to have odd and strange sizes mains and rod bearings/maybe they can be of help/have not ordered anything from them in a couple of years so can’t really state what they have or don’t have/i had a Merc crank that needed .050 rod bearings and they had up to .060 in stock. IMG_0714.jpeg
    1320 Fan and Algoma56 like this.
  8. Bearing Burner
    Bearing Burner
    from W. MA
    I read a long time ago that Fedral Mogal made .050 bearings. Been looking but never found any.
  9. Mr48chev
    Back in the day a lot of engines went though the rebuild shops so many times that the cranks were turned down a lot. Unless it was broken beyond repair it didn't get thrown out.
    arse_sidewards likes this.
  10. Budget36
    Budget36
    What, is turned down too much for Ford/Mercury crank?
  11. old school rodder
    old school rodder
    Merc cranks are pretty easy to find, and not very expensive. Seems like replacing the crank would be a better long term investment.
  12. tubman
    tubman
    When the surface hardening is removed. See my post #5.
    Budget36 likes this.
  13. Beanscoot
    Beanscoot
    Do stock cranks actually have hardened journal surfaces?
    When I've nicked them with a rod bolt, they didn't seem very hard.
