8BA water necks
Discussion in 'The Hokey Ass Message Board' started by 32Gnu, Nov 4, 2010.
  1. 32Gnu
    32Gnu
    I am looking for water necks for my stock heads with a 1-3/4 outlet.. Any ideas?
    Thanks
  2. 19Fordy
    19Fordy
    I think a hose reducer is available for stock outlets. Or you could make an alum sleeve with 1 3/4 OD , slide it over the stock outlet and weld it on. I changed the outlets on my radiator to match those on water outlets.
  3. tommy
    tommy
    Get the aluminum ones from most any hotrod parts supplier. You can paint them or powder coat them if you don't like the aluminum look. I'm sure Speedway has them.
  4. 32Gnu
    32Gnu
    Speedway is a no go, I am sure there is match to the bolt pattern.. If not may have to fab some up..
  5. iracer
    iracer
    Try Flathead Jacks. Saw them in their catalog a couple of months ago..
  6. tommy
    tommy
  7. Mr48chev
  8. 32Gnu
    32Gnu
    Yes I even spoke to the "tech" Guys..
  9. Hnstray
    Hnstray
    from Quincy, IL
    I made my own.....used a section of steel pipe for the neck....cut off the original cast iron outlet, enlarged the opening .............preheated with a torch and welded with stick welder and cast iron rod.....put them into a bucket of sand to cool slowly. Worked like a charm.
    Ray
  10. 51FordF2
    51FordF2
    from Indiana
