Technical 8rt FLATHEAD THOUGHTS??
Discussion in 'Traditional Hot Rods' started by Nos1partstore, Jun 5, 2018.
  1. Nos1partstore
    Nos1partstore
    I can purchase this 8rt FLATHEAD, side loaded transmission, driveshaft and complete 1946 rear end for $3000. What are y'alls thoughts. My experience includes only SBC's in the cars I have built so I am just an amateur mechanic but have wanted to challenge myself with a flathead set up. What are y'alls thoughts on the price? It would be going I in the 30 coupe pictured.
    Everything looks really clean and was told it all has been rebuilt, so I guess I have to trust him IMG_64631.jpg IMG_64641.jpg IMG_56551.jpg IMG_56561.jpg IMG_56141.jpg IMG_56481.jpg 20180515_175639.jpg
    Sent from my SM-G950U using The H.A.M.B. mobile app
    dwollam likes this.
  2. brsturges
    brsturges
    from Miami, FL
    Price seems high if the seller is a stranger. Any do***entation on the rebuild? Can you speak with the machine shop that worked on it?
    Automotive Stud and flatford39 like this.
  3. Nos1partstore
    Nos1partstore
  4. bct
    bct
    i think its on the high side too. if he has paper work then it is a fair deal.
    flatford39 likes this.
  5. Texas Webb
    Texas Webb
    All above and hear it run first.
  6. alchemy
    alchemy
    I'd say it's way too high for a pig in a poke. Can he pull a head, the intake, and the pan to prove the rebuild? If he expects to make 3 grand off these parts he's going to have to prove it is nice. A gasket set is cheap.
    Take along an experienced friend when you view the opened up engine.
  7. revkev6
    revkev6
    from ma
    I bought a undo***ented rebuild last summer. opened it all up. intake, heads and pan. paid half that for the motor. running in my roadster currently. good side shift box is worth a little coin for the gears to swap into a topshift case. 46 rear is a couple inches wider than the earliers 40 rear so it can look a little off depending on the build.
    Automotive Stud likes this.
  8. 48fordnut
    48fordnut
    If he can prove the build, and if you can hear it run. Could still be cracked.
  9. trey32
    trey32
    Thousand bucks.
    Buying flatheads is like playing the lottery...
  10. dan31
    dan31
    Rebuilt motor,trans and rear end for 3k,in my area that would be a home run if all are good.
  11. cadillacoffin
    cadillacoffin
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes. It’s really a ****shoot.
    See if he’ll agree on half the cost with the remainder on hold until you get it on the road.
  13. Uncle Bob
    Uncle Bob
    from Salado, Tx
    If it were all do***entable, and a physical inspection supported the paper claims, it could be a decent deal...….as most overpriced sellers like to say, "you can't build it for that.....".
    In the recent past I've followed up on ads like this. Usually they were anywhere from a couple weeks to a couple months old. Despite some fantasizing elsewhere on this board, our hobby is shrinking in interest (though not dead) with each p***ing day, which makes it tougher for sellers of this kind of package. I wouldn't give more than $100 for a strangers flathead if he wouldn't let me do as alchemy suggested above. Without inspecting the insides you've got a high probability of buying a dud when it comes to flathead V8s. Sellers with not much knowledge of flatheads balked at letting me do that because they believed a ****oned up engine enhanced value...…………..like I said, they don't REALLY know flatheads...…….or, more cynically, they know theirs probably looks bad inside. Like putting value on anything...………..condition, condition, condition.
    One additional comment for consideration, the '46 rear end is wider than the earlier ones, which can look a bit odd on a Model A...…..…...not awful, just not as nice.
  14. 2935ford
    2935ford
    Caution there my friend.....a little pricey for the unknown. Take head to what has been stated here.
  15. Atwater Mike
    Atwater Mike
    Three large is Capital money for this (unknown) package. Alchemy is right, as usual...Open it up and look.
    A new customer brought me a '46 Ford coupe for a Chevrolet transplant. He offered me the flathead in it ("rebuilt!") and a balance of $$$. When I finished the job, I discovered the transmission was blown. When I opened the flathead up, 2 spun bearings had wiped out the crank.
    But the Offenhauser heads and intake were good...
    (All that shineth's not gold...)
  16. Bearing Burner
    Bearing Burner
    from W. MA
    I have found 4out of 5 flatheads are cracked beyond use
  17. flatford39
    flatford39
    I just rebuilt one. I have close to $3,000.00 including machining in it. I did the ***embly myself. If you can do***ent what was done including looking for cracks it's a fair price. You need access to the machine shop that worked on the engine. I would have no problem at all letting a prospective buyer talk to my machinist if I was trying to sell my motor. But then again I would want more than $3K for it.
  18. 2muchstuff
    2muchstuff
    from Eastern KS
    Good advice from everyone above. When dealing in flatheads caution is the word. I acquired a "rebuilt" flathead with a project awhile back. Never been fired. Could see new pistons through the spark plug holes. Thought I'd change cams and install it in my roadster. It was "rebuilt" - new pistons, bearings, oil pump, etc. However it was bored too large and piston to cylinder clearance was excessive. The heads had been milled excessively and you could see where the pistons hit the heads just from rotating it by hand. The block had not been hot tanked! Valves had not been ground, but had been marked where they came out. They were not installed where removed. Half of a split guide was poking up into an intake port. Oil galleys were full of crud. On and on with half***ed poor quality work. Just glad I didn't pay for this one! I have a different block at the machine shop now and will install the new parts in the properly prepped block. Buyer beware!!
  19. dirty old man
    dirty old man
    Agree with all the cautions above. Also engine has 8BA head on left side and 8RT head on right side. Not familiar with 8RT but if cc of comb chamber in heads is different, there's another problem.
    Nailhead Jason and Hnstray like this.
  20. Mac VP
    Mac VP
    You’ve got three separate components there, with the engine being the most valuable. Heed the advice you’ve been given above. It’s not a critical problem in the so-called “rebuild “ but the non matching cylinder heads.....to me.....is a big red flag that the motor was not built by someone who cared about the work. With easy availability of matching heads, whether stock or aftermarket, why would anyone do that?
    I’d bet that the transmission has not been rebuilt. We do them for a living and have found that most people just go with them as-is and just repaint them for the next car. We see those transmissions after the owner realized the things didn’t shift right.
    GreenMonster48 likes this.
  21. 1946caddy
    1946caddy
    from washington
    Maybe the guy who rebuilt it thought the RT stood for right side of the engine.:p
    tubman likes this.
  22. Chappy444
    Chappy444
    FWIW, i have a receipt for just $5k for the flat head in my car(including machine work, parts, and ***embly)
    51 truck block
    4" merc crank
    Isky max 1 cam and valve train parts
    EAB heads
    additional cost for: 12V Gen, Mallory dual point built by Bubbas, vintage Edmunds 2x2 intake, ford script Holly 94's, rebuilt starter, higher flow water pumps...
    having said that i would probably be tempted at $3000 for an entire drivetrain.
    as others have said, Trust but Verify
    if you have access to one of those small endoscopes maybe you can check out the cyl through the plug holes.
    i have used this one in the past and it works pretty well.
    https://www.amazon.com/Endoscope-Bo...0683&sr=8-7&keywords=endoscope+for+cell+phone
