Technical 8RT to 37 Ford trans
Discussion in 'Traditional Hot Rods' started by trevorsworth, Mar 1, 2024.
  1. trevorsworth
    trevorsworth
    Hey guys. I just picked up a Z'd, stepped, and narrowed Model T frame for next to nothing and it's telling me it wants to be a single seat boat-tailed racer when it grows up. With so many other irons in the fire this is a long way out but I have a lot of the stuff I need to get started on it so I might as well give some thought to the drivetrain. I have a 1937 Ford V8 transmission that is raring to go. What bellhousing do I need to connect this to an 8RT flathead that currently has a 4spd truck trans hooked up to it? Someone told me the 8RT bellhousing is the one I need but that doesn't look right...
    Here's the frame...
  2. Theres an adapter for that.Theres one right now on e bay for 259 bucks if you want to see one. 32-48 to 49-53 transmission adapter.
  3. tubman
    tubman
    Generally, an 8RT (Ford truck) bellhousing is correct, as the later Ford trucks had a three speed transmission very similar to the early Ford p***enger car transmissions. The difference is that the later trucks have an open drive shaft while the early cars have a closed drive. An '49-early '51 Mercury bellhousing will also work. The main difference i that the truck bellhousing is cast iron and will accommodate an 11" clutch, while the Merc unit is restricted to a 10" clutch and is pressed steel. The usual solution is to use an early '50's Merc clutch.
    The four speed truck transmission uses what is called a "hogs head" which is very useful for other things (including mounting a T5 transmission). Don't let it get away.
    Budget36, LOU WELLS and trevorsworth like this.
  4. clem
    clem
    photos may help at this time ………
  5. trevorsworth
    trevorsworth
    It has been a long time (over a year) since the engine and transmission were in the same place so I was going off memory. It has been a long time since I looked at it closely and I won't be able to put eyes on it again for another couple of weeks, but I remember thinking the bolt patterns were different between the 37 trans and the 8RT bellhousing. Next time I am out there I will bring the transmission with me to compare fresh. I am just bench racing right now and wanted to start laying things out in my head.
  6. Squablow
    Squablow
    Keep in mind, there's kinda two pieces of bellhousing on the big truck transmission, there's a ring that's maybe 4" deep (that's the piece you're going to use) and then there's a little "hogs head" piece with the clutch fork rod running through it, which unbolts separately from the transmission. You won't use that hogs head piece, but be sure to keep it, as some guys redrill those for use with other transmissions and they have some resale value.
    trevorsworth likes this.
  7. Fortunateson
    Fortunateson
    More HAMB education!
    trevorsworth and Budget36 like this.
  8. tubman
    tubman
    One last thing. The early fifties Fords and Merc bellhousings all have a companion piece called a "starter plate", used for (guess what?) mounting the starter. These are not interchangeable between the different bellhousings, so make sure that you get the starter plate with the bellhousing. People usually save the bellhousing when s****ping a car, but for some reason are prone to throwing the starter plates.
    warbird1, trevorsworth and Budget36 like this.
  9. 19Fordy
    19Fordy
    warbird1 likes this.
