8x2 intake for big block chevy?
Discussion in 'The Hokey Ass Message Board' started by BAD ROD, Sep 14, 2010.
  1. 1moore
    1moore
  2. falcongeorge
    falcongeorge
    from BC
    ^^another weber intake. Webers were used by alot of USRRC and Can-Am teams in '66-'67, but then there werent many BB cars running Can-Am in those years either...
  3. Deuces
    Deuces
    H&M made one for the FE 427 that can be converted from running Webers too mechanical fuel injection stacks....
    Look up the Buddy Bar intake thread I started a while back... ;)
  4. Weasel
    Weasel
    Blue Thunder still makes them for the FE engines - here's an EFI setup for an FE....
  5. Jim Hall's Chaparrals used big block engines in late 1966 and 1967. Initially with 58 mm Rochester "Weber copies" and later with a Kinsler designed fuel injection system. Chaparral was GMs "unofficial" racing arm, and built their own engines (or GM built them, depending on who you believe). Hall was partners with a guy named Hap Sharp...although that may have nothing to do with the manifold. Many lesser funded Can-Am teams still ran carbs on into 1969.
  6. primed55
    primed55
    Is that Kinser setup (red stacks) yours? I'm 95% sure that was mine, if it is let me know and i'll tell you the back story (i still have the orginal motor it came off of).
  7. 1moore
    1moore
    This one as I said was a spare for Mickey Thompson and was a mechanical fuel injection unit.
  8. falcongeorge
    falcongeorge
    from BC
    And where do the nozzles go?
  9. Deuces
    Deuces
  10. Deuces
    Deuces
  11. milwscruffy
    milwscruffy
    Maybe it's just me but there's a whole lot of bolt holes missing for it to be Big Block Chevy. There's 16 bolts that mount the manifold to the heads on a BBC, on these I see about half that.
  12. Deuces
    Deuces
    They bolt in from inside of the hollow casting... ;)
  13. milwscruffy
    milwscruffy
    Sorry but from the photos provided wouldn't they end up in the throat for the carb/injector and if so i just didn't see any holes there.
  14. Deuces
    Deuces
    That I don't know.... We would have to find out from the guys that own those...
  15. 1moore
    1moore
    When you bolt the top portion on with the ****erflies on you will see where the nozzles go.:eek:
  16. Deuces
    Deuces
    We were talking about the main intake itself.... Do half of the bolts mount on the inside of your BBC intake???
  17. Deuces
    Deuces
    I sure would like to see the bottom of this BBC intake.... We need more pictures...
  18. milwscruffy
    milwscruffy
    x-2
  19. Deuces
    Deuces
    ...... As for the fuel injection adaptors... I could probably make a working prototype using T6 aluminum... Yes, billet!... :eek::rolleyes:
  20. old soul
    old soul
    from oswego NY
    That is a real cool peace!!!!!!
  21. Deuces
    Deuces
    Yeah, it is!!!... :cool:
  22. darkk
    darkk
    Christ! who cares what it is? If it's cheap, send me a PM and I'll buy it!
  23. falcongeorge
    falcongeorge
    from BC
    Ok, I'm game, lets see them.
  24. RichFox
    RichFox
    I had some of those injectors that are made to bolt to a Weber manifold. THJ or something like that. Have idle circuits and all. I believe Hilborn also made throttle bodies to bolt to the Weber mount. Not rare at all.
  25. falcongeorge
    falcongeorge
    from BC
    The point isnt whether there are throttle bodies that will bolt to a weber or just about any other carb bolt-pattern you name. There are. The point is, as you have stated in your post, this is a weber intake. Which it is.
  26. Telcalamit-Jackson, Rich? They did a lot of those Weber manifold conversions for small-block Fords, I believe.
  27. [​IMG]
    Nope, no holes in there... Lots of sealant and a short prayer, I think.:D
  28. Deuces
    Deuces
    Yikes! :eek: That's scarey....
    I'd be worrying about vacuum leaks....
  29. Weasel
    Weasel
    Injector pockets go in the throttle body barrels and run on the inside for better fuel distribution:
    TWM throttle bodies - these are the ones used by both Roush and Inglese formerly out of Goleta CA but now in Johnson City TN having been acquired by Borla.
    www.twminduction.com
  30. Weasel, aren't those slide throttles on your Weslake heads (under the FI adaptors)? Damn...I gotta clean the drool out of my keyboard every time you post a picture of that thing.
    I hope those heads worked better than the ones on Surtees big-block...
