Technical 9” axle drum help
Discussion in 'The Hokey Ass Message Board' started by 1940Coupe, Jul 23, 2018.
  1. 1940Coupe
    1940Coupe
    hi
    I have no idea which vehicle this axle is off so am unsure which brake drum parts to buy.
    Being in the UK I don’t want to buy the wrong parts
    All I’ve found out is
    31 spline shafts
    5x5.5” bolt pattern
    64.75” wide
    Drum has
    Max dia 11.12
    Shoes (this is not right I’m sure)
    1 at 12” x 2.25 (handbrake)
    1 at 11.75” x 2.25 ( handbrake)
    2 at 9.5” x 2.25
    Grateful for any and all help
  2. squirrel
    how about some pictures?
    And how are you measuring the shoes?
  3. 57 HEAP
    57 HEAP
    So you need drum brake parts, what exactly, for an 11" diameter drum with 2 1/4" wide shoes.
  4. squirrel
    Probably something like a 1975 F100, with 11-1/32 x 2-1/4" brakes, eh?
  5. 1940Coupe
    1940Coupe
    Had a quick search around and found the diff tag.
    Managed to decode it he tag and if I’m right it comes out as a 78-79 F150
    I know the ring gear was correct as I’ve swapped it for a 3.25
    What are other people’s thoughts
  6. 1940Coupe
    1940Coupe
    If it’s as simple as that, then yes that’s what I need
  7. 1940Coupe
    1940Coupe
    That’s the thing there seem to be a fair few to choose from
  8. 57 HEAP
    57 HEAP
    the OP asks about drum brake parts. Again, what do you need? Springs would be drum brake parts. Wheel cylinders, shoes, and ........
  9. 1940Coupe
    1940Coupe
    Everything apart from backing plates,
    Drums
    Shoes
    Wheels Cyls
    Fitting kit
  10. squirrel
    look up a 1978 F150 and see it it uses that same size shoe, and if so, order your parts.
    Again, pictures of the brakes would help us help you....
    Hnstray likes this.
  11. warhorseracing
    warhorseracing
    from cameron wv
    You will find a few available widths and diameters for any specific year. Definitely as said before, some pictures, preferably with a measuring tape beside the parts.
  12. bobss396
    bobss396
    Measure the drum depth (where the shoes contact..) and subtract a 1/2". That will be your shoe width. Kinda of a rough way to source shoes but it works. If that fails go with what Squirrel recommends.
  13. 1940Coupe
    1940Coupe
    Hopefully this will help
    Shoe width 2.25”( worn in grooves)
    Ebrake shoe at 12”
    Ebrake shoe at 11.75”
    2 other shoes at 9.5”
  14. 1940Coupe
    1940Coupe
    I’ve just looked up on rock auto for a 78 and they still have different shoes
    11”x2.25”
    11 1/32”x2.25”
    And another just saying for 11.03 drum
  15. Boryca
    Boryca
    from Detroit
    I think you're overthinking this. Sounds an awful lot like a basic issue, and it's new enough that your local Napa likely has stuff for it. Shoot, even one of the other chain joints might have them. Pick up a set of shoes for $25-30 bucks, add in a hardware kit, and if you need wheel cylinders, likely $20-25 apiece. You'll likely find all three of the options you list above will fit, especially if you have the drums turned or buy new drums.
    Atwater Mike likes this.
  16. 1940Coupe
    1940Coupe
    Looks like I’ll have to do that.
    Only problem I was having was, as I’m in the UK returning wrong parts is not an option.
    Just have to take the gamble.
  17. squirrel
    11.03= 11-1/32. The clue that his is the correct size, is the MAX DIA marking of 11.120" which equates to 11.03 + .090 max allowable wear.
    Yes, you are getting a bit too worried about it...
  18. 57 HEAP
    57 HEAP
    Look closely at the wheel cylinders and brake shoes. There may be part numbers that you can use.
    Since the drum is 11.12, then get the large 11 1/32 shoe, the wheel cylinders shouldn't differ much as other parts I would guess. Rockauto often has pictures of what you are buying, so use that feature. Good luck.
  19. 1940Coupe
    1940Coupe
    That’s where i was getting confused with rock auto.
    Many thanks for the help and I’ll get the parts ordered.
  20. 1940Coupe
    1940Coupe
    Yeh already seen the wheel cyl’s. thanks for the help
  21. 1940Coupe
    1940Coupe
    Thanks for all the help and advice. Thought I might be looking into it maybe too hard but only like to buy things once.
    57 HEAP likes this.
  22. Boryca
    Boryca
    from Detroit
    Ah, yeah, I wondered if you might be outside the states. If you're getting new drums too, I wouldn't go with the 11 1/32, as that will be a bit big. If you're re-using drums and getting them turned, they'd likely work fine. They'd likely work fine either way, but might wear a bit fast and inconsistent initially.
    Springs and hardware should be the same regardless.
  23. 1940Coupe
    1940Coupe
    Many thanks:)
  24. squirrel
    uh....there are two different sizes of drums that Ford used, the earlier trucks had 11x1-3/4 or 2" shoes, the later ones had 11-1/32 x 2.25 shoes.
    Just make sure the drums and shoes are for the same setup.
  25. 1940Coupe
    1940Coupe
    Thanks. Will do
