Technical 9.3 identification
Discussion in 'The Hokey Ass Message Board' started by Jmos4, May 16, 2026.
  1. Jmos4
    Jmos4
    Hi,
    I picked this up locally today
    It's been narrowed 50/51 inches flange to flange. Appears to have guessing Ford ends/brakes aftermarket 31 spline axles measure about 1.5" OD.
    The third member is a casting number 522496 3 fin with 3.42 stamped on one of the webs. Also no casting date just a Square casting a w or m in the middle.
    Also has 5.86 gear ratio (7/41) and a 2 piece posi the only casting numbers I can make out is 30942.
    I have the Fabcraft manual but don't see any of the numbers from this axle.
    So what do I have?
    Regards,
    Jim
  2. bobscogin
    bobscogin
    According to this photo off the internet, the Ford 9 3/8" can be identified by the top rib that curves downward. Can't confirm that. Is it present on yours?[​IMG]
  3. Pete Eastwood
    Pete Eastwood
    from california
    It's an Olds / Pontiac rear end.
    Can't tell from the pictures if it's the early small one or the big "57-"64 version.
    Toms Dogs, jimmy six and Just Gary like this.
  4. Bird man
    Bird man
    from Milwaukee
    Nice find whatever it is!
    31 spines indicates later carrier, but that info is in Brad's book.
    3rd member ID should be in the book too?
  5. patsurf
    patsurf
    he needs the m/t mag housing!
  6. Jmos4
    Jmos4
    Hi,
    It's a 9.3 Pontiac/Olds just the casting number is 57/58 yet has 3 ribs like a 60-62 and has a different square cast where you normally see a date code also weird it's stamped 342
    Regards,
    Jim
    Pete Eastwood likes this.
  7. jimmy six
    jimmy six
    Great rear end. Higher pinion placement takes less hp. New lower gears if using an overdrive trans. In its heyday one of the best rears for drag racing.
    Toms Dogs likes this.
