Technical 9" drain Plug
Discussion in 'The Hokey Ass Message Board' started by Kustom292, May 5, 2023.
  1. Kustom292
    Kustom292
    from Winnipeg
    I have been looking but cannot find the drain plug for the 9" ford diff I have been working on. Does anybody know the size so I can get a replacement. It is out of a 58 Ford Custom 300 4 Door. I hate when the gremlins take parts for a walk.
  2. tommyd
    tommyd
    from South Indy
    It should be just a pipe thread size. Any hardware store I think.
    4ever18 likes this.
  3. Should be a 3/8" pipe plug if it's a factory drain.
  4. swade41
    swade41
    from Buffalo,NY
    I don't think the carrier had a plug in those early years, it was in the housing
    Bill Whitehurst and panhead_pete like this.
  5. The carriers never had a drain plug, any drain was always on the housing. Ford installed drains in the '57, 58 and some '59 housings, after that they disappeared.
    Truckdoctor Andy likes this.
  6. tommyd
    tommyd
    from South Indy
    Only fill plugs. I think that's what he's looking for.
  7. There are two types/sizes of plugs. The fill plugs are 1/2" NPT, drains are 3/8" NPT. If you're in a plumbing department, they'll have the standard pipe thread taper on the plug which isn't what you want. Most of these also have a square male head for tightening. Electrical/hydraulic plugs use the same thread minus the taper and will have a female socket for tightening; 3/8" for 1/2" and 5/16" for 3/8" in either square or hex (allen). The taper is in the female thread they go into.
    4ever18, Tow Truck Tom and indyjps like this.
  8. Mr48chev
    Fill plug on the side of the pumpkin, Fill plug on the back of the case or no fill plug if you put the wrong combo together in the bought a third member and stuck it in my housing thing.
    I've got 4 nine inch housings, three F150 and one Galaxy and none have a drain plug and I don't ever think I saw a drain plug in one. nine inch fill plug (3).jpg
    Yuppers the photo is upside down so the rear is in the proper orientation.
    2Blue2 likes this.
  9. bobss396
    bobss396
    Some of the factory plugs had a 5/16" square socket instead of a hex. Good thing I have lathe bits around. I replaced it with one that takes a hex key, from Ace Hardware.
  10. RmK57
    RmK57
    My factory 57 housing has a 3/8 pipe with an oddball female square drive. It’s not 3/8 or 5/16.
    CSPIDY likes this.
  11. CSPIDY
    CSPIDY
    I hear ya,
    had to grind one down to fit our 57 Tbird
  12. ekimneirbo
    ekimneirbo
    When I take the pumpkin out of any Ford housing, I always add a welded on drain plug on the bottom of the housing. Makes it a lot less messy if you ever have to remove the pumpkin again.
    Bill Whitehurst and Algoma56 like this.
  13. 1946caddy
    1946caddy
    from washington
    Think outside of the box.
    The Shift Wizard and bobss396 like this.
  14. Budget36
    Budget36
    I thought you (third person) took the bottom pumpkin bolts out and let it dribble into a pan?
    panhead_pete likes this.
  15. RmK57
    RmK57
    Good if you have a hoist. I wouldn’t place a jack on the plug.
  16. nochop
    nochop
    from norcal
    Pull the axle…..that’s my drain. FYI….make sure you have axle seals.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Also provides a convenient snag point for road hazards !
  18. ekimneirbo
    ekimneirbo
    If something in the road sticks up that high, I probably already have greater problems ahead of the rear end.This definitely isn't the lowest point on my car/truck.....so I'll risk it.
    The example below is not my car, but typical of the 32 I'm building.
  19. ekimneirbo
    ekimneirbo
    Most floor jacks have a cupped shaped dish and I haven't had any problems when jacking cars up with this modification. Its actually pretty solid and works well for me. It helps that I picked up a couple of "drain plug" service boxes at an auction. Got lots of drain plugs for almost nothing.
