Technical 9" Ford Back Truss
Discussion in 'Traditional Hot Rods' started by FNG, Mar 12, 2021.
  1. swade41
    swade41
    from Buffalo,NY
    I've seen a few rear ends with slight V shaped tubes welded right on the bottom of the circle (if you will) then outward to the coil over mounts to prevent twisting, like this.
  2. squirrel
    sometimes off road vehicles have a truss under or over the axle housing, for vertical loads. The one across the back is for front/back loads, caused by the tires pulling the ends of the axle forward, while the inertia of the car, acting through the rear suspension, tries to hold the housing back.
    kidcampbell71 likes this.
  3. DDDenny
  4. Mr48chev
    From a been there done that. Just take the tank off and clean it out and be done with it before you run it. You are going to take it off sooner or later. Later being after you plug up three or four fuel filters if you have them in front of the pump. It might be a pain in the **** to clean the tank first but it is a royal pain in the *** to lay under the car changing a plugged up fuel filter.
    swade41 likes this.
  5. anganman
    anganman
  6. Zax
    Zax
    Yes, but not in a rod. I used a f100 9 inch housing for a Jeep CJ project. Much easier to bend a housing doing off road than street applications.
    Had a friend that is a professional fab guy do the welding. He worked on it all day off and on so it did not warp from heat.
  7. birdman1
    birdman1
    Or a t5 transmission
  8. birdman1
    birdman1
    The 9" in my 58 t bird broke at the right side axle tube. Had the coil spring rear end. I welded it up and put a strap iron brace on the bottom.
  9. 1952henry
    1952henry
    If the brace Squirrel has works, I would go with it. With his hp, and the fact that he drives his car to a race, steps into it hard, then drives to another race, it would be something to consider. I would rather doubt he would be tooting it otherwise.
