Hot Rods 9 Inch Ford Help!
Discussion in 'The Hokey Ass Message Board' started by 31bowtie, May 6, 2018.
  1. 31bowtie
    31bowtie
    from maine
    I am replacing the pumpkin/third member in my 9 inch Ford rear end and have a dilemma. The casing that is in my truck has no fill plug in it, and the third pumpkin/member that I am putting in does not have a fill plug in it. How do I fill check the fluid? Do I need to drill and thread in a filler plug?
    Boneyard51 and chryslerfan55 like this.
  2. 19Fordy
    19Fordy
    The 3rd member metal is about 1/8 in. thick so rather than drill and tap,
    weld in 2 threaded bungs. One to fill. One to drain. Use pipe thread.
    Baron, loudbang and Hnstray like this.
  3. Boneyard51
    Boneyard51
    Look to see if the boss is cast in your third member. If so just drill and tap. Bones
    loudbang, camer2 and Hnstray like this.
  4. What 19Fordy said..... Might as well add a drain as well.
    Reminds me of one of those horrible tv shows. They had same problem and only two minutes to fix. They put a couple quarts of gear lube in ziplock bags and stuffed it together.
    Hnstray, rjones35 and vtx1800 like this.
  5. Sheep Dip
    Sheep Dip
    from Central Ca
    Oh Lordy Lordy!
  6. 1946caddy
    1946caddy
    from washington
    rc57 and loudbang like this.
  7. Shamus
    Shamus
    from NC
    Seems I saw a tech article on that very subject recently - Street Rodder, Cl***ic Truck or similar pub.
  8. Yep, all of them I've seen have the fill plug boss, just not always drilled. Most machine shops can drill/tap that for you... You can do it yourself with a 1/2" pipe tap, but make sure you get all the chips out.
    Boneyard51 likes this.
  9. Boneyard51
    Boneyard51
    An old trick my dad taught me to do in drilling and tapping where you cannot clean the other side, is to use grease on both your bit and tap. The grease with capture most of the shavings and chips. Bones
    31bowtie likes this.
  10. 19Fordy
    19Fordy
  11. RICH B
    RICH B
    Or you could take a wheel off and let that side down to the ground, jack up the other side, pull the axle, and pour the gear lube down the tube. If it is bordering around 0 degrees and you are working in the alley, you may have to heat the oil up on the kitchen stove (at least until your mom smells what you are doing). Oh! to be young and stupid again; well, at least the young part.
  12. I had the same deal three weeks ago, with an 8” going into my shoebox. I didn’t notice til it was all together and ready for oil. Doh!
  13. cbillelder
    cbillelder
    If you know how much oil the rearend requires, how 'bout just removing the air vent hose and fitting and adding the oil thru that hole?
    j-jock likes this.
  14. I had to use the vent to pull out the old gear lube and add the new gear lube in an O/T rear end.
    I have a hand pump, and just attached a piece of hose that was small enough to fit in the tube. It worked like a charm.
    Bob
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Put one axle in and wheel-tire on that axle then set it one the ground. Now jack up the side without axle and pour lube into axle tube then cap it with the other axle.
  16. Groovy
    Groovy
    If you have a vent tube jut remove it and fill from there. Did that on a Ford 8.8 rear end.
  17. F-ONE
    F-ONE
    from Alabama
    Drill and tap it!
    Filling from the vent or axle is ********!
    Montana1 likes this.
  18. Sheep Dip
    Sheep Dip
    from Central Ca
    I agree....how the hell will you ever check fluid level during maintenance?
    F-ONE likes this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Easy and fast when your in a hurry. You want serious? I prefer welding bung's in place. One to fill and one to drain.
    F-ONE likes this.
  20. Boneyard51
    Boneyard51
    This all depends on where he is at in his build. If it’s in the car complete, drill and tap the third member, with the technique I mentioned earlier. If the rear end is dis***embled, setting on the work bench, weld two bungs in it. Bones
  21. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    So you said initially that you were PUTTING in in (implying it was still out), what's the big dealer drilling and tapping it now?
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You and F-ONE are so serious it's hilarious. :)
    Hnstray and F-ONE like this.
  23. 31bowtie
    31bowtie
    from maine
    Thanks for all the replies. I ended up drilling and tapping it. Went very well and did not experience any issues.
    Hnstray likes this.
  24. Hnstray
    Hnstray
    from Quincy, IL
    X2. :D
    Ray
