Technical 9 inch ford
Discussion in 'Traditional Hot Rods' started by Crazy Hessy, Aug 30, 2021.
  1. Crazy Hessy
    Crazy Hessy
    from Ohio
    1932 roadster,what size 9 inch ford rear end ?( hub to hub size.for best fit?) Thanks.
    Deuces likes this.
  2. X38
    X38
    Depends on your wheels.
  3. Dino 64
    Dino 64
    from Virginia
    Pete &Jakes rear ends are 56” wide for reference :)
    Crazy Hessy, Deuces and rbrewer like this.
  4. DDDenny
    Fendered or hiboy?
    Deuces likes this.
  5. gimpyshotrods
    gimpyshotrods
    56"-58" is the ballpark.
    If searching for one out of a vehicle, one from a first-generation (1966-1977) Ford Bronco is 58", has a 5-on-5-1/2" bolt pattern, and decent drum breaks.
    But yes, depends on wheels and fenders.
    lake_harley and Deuces like this.
  6. The previous replies will determine the overall width you want, in addition to bolt pattern, and whether a centered pinion is desired. The early Bronco rear has an off set pinion. Centered pinion 9" include 57-59 Ford (56.5" wide, 5 x 4,5 bolt) 57-59 big Mercury ( 58" 5 x 5). Determine the width and pattern, and a quick internet search will give you some good choices. If not too much HP, an 8" out of a V8 Maverick is a good choice at 56.5"
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Get the wheels and tires you plan to use and set them next to the body. Decide if they are wider than your outside fender lip (if you want fenders) or narrower than your outside fender lip (if you want fenders). If the outside edge of the tire is wider than your fender, you may need to cut the inner fender wells to move them in. If they are narrower than your fenders then move them out till they look right. The relationship of the outer tire edge to the fender means a lot about how a finished car will look.
    Even if you don't plan to run fenders, its best to plan for possible later installation of fenders on your open wheel car.
    Once you have found just how you want your tires positioned and you have the correct size tire and rim sitting there, then measure and see what width rearend YOUR car will need. You may (probably not) be able to find something exactly the right width or close enough to work......BUT you need to know based on the tires and wheels you plan to run. Lots of people have found that the tires and wheels they planned to run did not fit ....or fit well.....when they used different wheels/tires for their moch up.
    Crazy Hessy, Joe Travers and squirrel like this.
  8. RICH B
    RICH B
    I know someone who narrowed his axle twice; because he relied on specs instead of waiting for his wheels to show.
  9. DDDenny
    Happens a lot.
    Deuces likes this.
  10. Atwater Mike
    Atwater Mike
    I installed a Mopar 8-3/4 rear in a '41 Chev for a perfect fit. Chev was just finish painted, so I centered it all up and mounted it onto the semi-elliptic rear springs.
    Left side was perfect, right was 3/4" 'in'. I measured again and again, plumb bobs, etc.
    Chevy friend dropped by, there were two different rear fenders on this coupe! ('46-'48 was wider???)
    Owner said to "fix it, don't touch my fresh painted fenders!"
    Buddy Jim at Quality wheel reversed some Buick outers, one 'dumped' deeper...Perfect fit.
    I'll never admit it... (laughter)
    Some people's customers!
  11. Crazy Hessy
    Crazy Hessy
    from Ohio
    Fenderless
  12. Crazy Hessy
    Crazy Hessy
    from Ohio
    Fenderless
  13. HOTRODPRIMER
    HOTRODPRIMER
    I to like the early Bronco, it is the right width and it keeps the original big bolt pattern, especially when your building a traditional car using 40 Ford brakes up front. HRP
  14. Crazy Hessy
    Crazy Hessy
    from Ohio
    Highboy
  15. Crazy Hessy
    Crazy Hessy
    from Ohio
    Thanks everyone for all the Information.
    ekimneirbo likes this.
