Technical 9 inch rear flanges
Discussion in 'The Hokey Ass Message Board' started by 4EyedTurd, Jul 18, 2014.
  1. 4EyedTurd
    4EyedTurd
    from Texas
    Looking at 9 inch rear ends, this one has an unusual flange on the front of it. Could you run a normal 9inch style drive flange on it instead of that one? Or can you still find a driveshaft flange like that still?
  2. 1930 A
    1930 A
    By the looks of it that just takes a late model flange that is held on with four bolts
  3. squirrel
    Or you can buy a new flange to fit a normal U joint. You get into the pinion bearing preload when you do that, so read up on it first.
    Might be easier to find the matching driveshaft...
