Technical 9-inch washer?
Discussion in 'The Hokey Ass Message Board' started by miller, Feb 17, 2024.
  1. miller
    miller
    from New Jersey
    Hi, I am getting ready to put a ford 9 in center section in the housing. My question is how important are the washers? Can a sealer be used in place of these and not leak? Thanks
    Oneball likes this.
  2. squirrel
    you can get away without the copper washers, most guys don't bother with them.
    Oneball and mad mikey like this.
  3. miller
    miller
    from New Jersey
    Thanks for the info..
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    325w, Hnstray, SS327 and 6 others like this.
  5. i.rant
    i.rant
    On the **** side…….I use them along with a dab of Right Stuff.:D
  6. Oneball
    Oneball
    Following on from the initial question do you find if you pull a bolt to drain the axle it stays dry when you put it back in?
    I ****ed it out this time but need to do it again. My rear end is seemingly leak free, so much so I ***umed it must be empty when I got it!
  7. onetrickpony
    onetrickpony
    from Texas
    Those copper washers are reusable. I hammer them flat and aneal them with a propane torch. I've never had a leak reusing them, but I have had one when I didn't.
    RMR&C and Oneball like this.
  8. krylon32
    krylon32
    from Nebraska
    I use them, still get them at the local Ford dealer.
    427 sleeper likes this.
  9. miller
    miller
    from New Jersey
    Thanks for the replies.
  10. saltracer219
    saltracer219
    I use them, they will likely seep a bit around the studs if you don't.
    427 sleeper, SS327 and RMR&C like this.
