90 deg under dash pedal assy?
Discussion in 'The Hokey Ass Message Board' started by Bungi, Jul 21, 2010.
  1. Bungi
    Bungi
    Guys -
    Does anyone know of any manufacturesrs of the under dash pedal assemblies that mount the master cylinder at 90 degrees (parallel to the firewall) from the pedal?
    Or anyone have plans to build one?
    Thanks
    Rick
    Janesville, WI
  2. onlychevrolets
    onlychevrolets
    Theres a 53 International at our shop with that setup. I'll ask who built it.
  3. primed34
    primed34
  4. sdluck
    sdluck
    Dodge vans of the 1970 had a sidewaysmounted brk master cylinder.
  5. brandon
    brandon
    treed me on that one.... :D
  6. Kerrynzl
    Kerrynzl
    RHD E30 BMWs had the master cylinder brake booster on the Left side [ because of the slant engine ]
    They used a pair of 90 degree bellcranks and a "pull rod" under the dash.
    [ they are terrible when they get a bit of wear ]
  7. Steves32
    Steves32
    from So Cal
    I have the Kugel one under my dash.
  8. Weasel
    Weasel
    Or you could try Kugel in La Habra CA:rolleyes:
    I got one from a late 70's or early 80's Econoline van in a wrecking yard - $20, which is pretty much what Jerry Kugel copied his setup from.
  9. LT4 Hawk 9
    LT4 Hawk 9
    I've got ECI's in one of my Scouts. Very well built, and it works great so far. Of course, it's just been hanging there not hooked up or moved for the past 3-4 years.... Anyway, it looks to be a little bit less expensive than Kugel's piece. Might be worth a look-see.
