can you get the jets that are in the bottom of the float bowl. mine aren't bad, but close to getting stripped. i am rebuilding a 94 8ba, and want it to be good as can be.
Stop messin'up the apartment!!!You missed another chance to get the merc to PA.I will bring it here someday!
lulabelle, thank you for pushin....i need it...i am trying to figure something out. local stores huh. what are the sizes of these jets, i can't read it on the side. anyone?
Holley jets are the same. Mine were 51's. I put 55 in my center carb and 48's on the ends. Get them at vintage speed or summit. himmelberg
thanks himmel...i will get some...are you running a 3 duece with a progressive linkage? sounds cool.. i will definitely investigate..
Summit ships the same day, Vintage Speed may ship in the same year. 51 is stock size in the 8BA 94 at sea level. Whikle youre at it get a spare power valve of various ratings or two, especially if you will be going multiple carbs. The 4.5 or 5.5 seems to work best with dual carbs and stock to rather warm cams.
