Technical !940 Ford Coupe
Discussion in 'Traditional Hot Rods' started by jumbogem29, Jul 17, 2024.
  1. jumbogem29
    jumbogem29
    from Alabama
    Does anyone know the correct WMS TO WMS front drum to drum wheel mount on a 40 ford did searh on hamb but only came up with the rear thanks
  2. alchemy
    alchemy
    I would bet the front is the same as the rear.
  3. jumbogem29
    jumbogem29
    from Alabama
    I might take you up on that bet that its not .
  4. 19Fordy
    19Fordy
    GOOD NEWS: I just found the notes I made in 1999 before I installed my Magnum axle. I made a few measurements and found the following:
    My stock OEM 1940 Ford coupe front axle WMS to WMS distance with stock Ford drums
    was 57 inches.
    Hope others can measure the distance and post it.
    In addition:
    Here's a thread on Fordbarn that gives the 1940 Ford track width. If you know the offset and wheel back spacing I bet you can calculate the WMS to WMS.
    1937-1940 Wheel Track Width - The Ford Barn
    neilswheels likes this.
