History 9in identification
Discussion in 'The Hokey Ass Message Board' started by JohnnyCASHcadillac, Jan 29, 2020.
  1. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  2. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  3. RmK57
    RmK57
    If that's a 5 then build date would be December 1 1965.
    What it looks like to me is a truck housing and somebody has swapped in a differential from a Galaxie, Fairlane or some other Ford car.
  4. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  5. Pewsplace
    Pewsplace
    Nine inch — see the goggle site listed above. Easy to tell if you look at the video. An eight inch has a flat spot on the top and the case has no ribs in the upper case.
  6. squirrel
    So...when you take off the wheels, how wide is it, from wheel mounting surface to wheel mounting surface (drum to drum)? Inquiring minds want to know.
  7. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I’ll get back to you in a few!!
  8. 31Apickup
    31Apickup
    I’m guessing it’s a pickup rear. Here’s my 66 Bronco rear, had a big drain plug. It’s the best picture I can get right now.
    [​IMG] View attachment 4560122
  9. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  10. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  11. swade41
    swade41
    from Buffalo,NY
    Definitely not an early bronco, like was said they all have the hump on the rear, I have 3 of those rears. 000_0003.jpg
  12. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  13. metlmunchr
    metlmunchr
    I've got one that's still in a bare 69 Bronco frame. It definitely does not have a pinion snubber. And it definitely measures 58" from WMS to WMS.
    Mine was bought new by a defense contractor whose security guards used it for patrolling the plant site. Someone left it idling when they went into a buiilding to eat lunch and it had an engine fire. I bought the remains in 73 for $50 when they were auctioning off a bunch of stuff as the Viet Nam war was beginning to wind down. None of that is of any significance other than to say the rear axle is an original example and not some mish mash of parts.
    One thing on mine that I've never seen on another early Bronco is that it has 16" tubeless wheels that are either 5 or 5.5 inches wide. All the others I've seen had 15" wheels.
  14. RmK57
    RmK57
    no point in having a pinion snubber on a Bronco, The differential is over a foot away from the floor. The third member in question is more than likely from a 65-66 Ford car and the housing is early to mid-60's pickup.
  15. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    So what would I identify this rear as?
    It’s an early housing with a 65 diff.
    At 61” long.
    That’s makes it from what??
    What would the common gears be?
  16. RmK57
    RmK57
    Outside
    Width
    Year Model
    56.50 1969-1977 Maverick 8"
    56.50 1990-1992 Ford Ranger 8.8"
    56.75 1995-2003 Ford Explorer 8.8" Narrowed w/2 short side axles
    57.00 1974-1978 Mustang II 8"
    57.25 1957-1959 Ford, Ranchero, Station Wagon
    57.25 1965-1966 Mustang
    58.00 1966-1977 Bronco
    58.00 1964-1965 Falcon
    58.00 1977-1981 Granada/Versailles
    58.50 1977-1981 Versailles
    58.50 1993-2009 Ford Ranger 8.8"
    59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
    59.81 1995-2003 Ford Explorer 8.8" 31 Spline Disc Brake
    60.00 1967 Cougar
    60.00 1958-1960 Edsel
    61.00 1964-1971 Ford Full Size
    61.00 1949-1951 Mercury
    61.25 1957-1972 Ford F-100 Pickup
    61.25 1960-1964 Ford Full Size
    61.25 1971-1973 Mustang
    61.25 1967-1973 Torino, Ranchero, Fairlane
    63.00 1970-1979 Ranchero & Torino
    63.00 1972-1979 Ford Full Size & Intermediate
    63.50 1967 Fairlane (Coil Springs)
    65.25 1973-1986 Ford F-150 Pickup
    65.25 1978-1986 Bronco
    65.25 1973-1986 Ford Van 3/4 Ton
    68.00 1972 Ford Van 3/4 Ton
    69.25 1977-1986 Ford E-150 Van
    brigrat likes this.
  17. alchemy
    alchemy
    Looks like an early pickup rearend. Bolt circle is 5.5" right?
  18. squirrel
    You can count turns to figure out the ratio. Being an early 60s truck, expect something around high threes to low fours for the ratio.
  19. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I know it’s about 2” off from stock 40. Is this gonna mess up fitting under with parallel leafs and wheel/tires
  20. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  21. squirrel
    Maybe you got ahead of yourself?
    warbird1 likes this.
  22. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Got me.....
  23. Mr48chev
    Too narrow or too wide?
  24. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  25. Pop Chevy
    Pop Chevy
    I have one of those. Round back, came out of a 64 station wagon. Had nice big brakes on it too. 5 x 5 bolt pattern.
  26. Budget36
    Budget36
    I think we knew that would happen.
    OP....only you know with your car if a different offset wheel will work.
    Now that we know you have a tape measure, start putting it to use.
    swade41 and Asphalt Angel like this.
  27. 47ragtop
    47ragtop
    My experience with 40 Fords The Bronco and Scout Ii rear axles are both 58 WMS to WMS and work great using 7 to 8 inch rear wheels with 0 to .5 inch offset. A 57 Chevy rear is 60 inches and work well with 6 to 7 inch wheels with 0 offset. My 40 runs either 6 inch F100 wheels or 7 inch Old Real Americans with 1/2 positive offset. They are close to the fender inside radius just about the wheel width limit IMO.Here are some pics with 58 inch rear and above mentioned wheels. A 61 inch rear would severly limit wheel choices. Later Bill
  28. squirrel
    Yeah, it looks like you'll be fine, as long as you get wheels that will fit. We don't know if you are looking to run skinny or wide wheels, what tires, etc. The post above should get you started, though.
  29. BamaMav
    BamaMav
    from Berry, AL
    If it's too wide, you can always narrow it. Like was suggested earlier, set up the wheel and tires you want to run under the fenders where you want them, then measure from the back wheel mounting surface on each wheel. That will give you the width you need.
    Even if you have to narrow it, it's still a good deal. 9" rears are getting hard to find. Good thing is you can buy everything you need from axles to bearings and seals to make it work like you want it to.
