9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. squirrel
    I have no idea what tomorrow holds, the weather is threatening rain most of the day..
    Today's data log.
  2. Did the running issue clear up after the the plug wire change?
  3. AmishMike
    AmishMike
    Afraid ****tered rain tomorrow, worse on Thursday at Cecil & Friday even worse unless storm p***
    41 GMC K-18 and porkshop like this.
  4. squirrel
    It's hard to say.
    I had lost one of the springs I had on the exhaust flapper, and it was making some extra noise on the drives, but I got a new spring and that part is quiet now.
    I get hyper sensitive to little changes in how the car sounds, etc, and it really seems to be doing just fine. I don't know for sure if it was misfiring before, it could have been...but it seems to be working great overall. I'm just not quite used to it yet! it's still pretty new.
  5. RodStRace
    RodStRace
    Having lived with those old Yellow wires, being a smog tech and having to tune thousands of cars, a plug wire like that will start out jumping only under high load, not idle or light load. Highway will get hot too, but it's when cylinder pressure gets high that the spark decides the pipe is an easier jump.
    You could have the Missus power brake it in gear and load it, looking/listening for spark before a run. Not exactly a full test, but better than nothing.
    Hope you both have a great, safe time.
  6. squirrel
    thanks
    I'm just not going to worry about it right now...we get to deal with on/off rain today, so that will keep me busy. Looks like it will start about the time we're supposed to start racing, then let up for a few hours, then start up again. So it's not likely that every car will get to make a p***, which means that no one has to turn in a time slip, and the day does not get averaged into the times for each car.
  7. Hellpig
    Hellpig
    Friday is calling for mid to upper 80s and sunny here in Southern MD. Rain should end tomorrow by midday, so I expect Friday should be GTG.
    Only caveat is that I DO have my own personal black cloud that follows me around...
    I'm close enough to MIR to FEEL some of the cars, lol.
  8. squirrel
    So far the weather is cooperating
  9. squirrel
  10. slowmotion
    slowmotion
    Is that Finnigan next door?
    Good luck Jim.
  11. Finnegan's had some wild rides this week
  12. squirrel
    Yeah we were next to Mike this morning.
    PXL_20250917_200316505.jpg PXL_20250917_155256572.jpg PXL_20250917_111729930.jpg
    rod1, Deutscher, Uncle Ronn and 15 others like this.
  13. squirrel
    It was fun meeting Amishmike today.
    We got into some rain, first time in this car. It did fine. The wipers work, and it doesn't leak much.
  14. Have a safe journey, Jim. :)
  15. Deutscher, porkshop, Sharpone and 2 others like this.
  16. Hellpig
    Hellpig
    Is that the Vette that went 8.36 on all motor, SBC?
    That thing was FLYING!
    Good luck and safe travels!
  17. Ha HA I see your wife remembered the wheel chocks.
  18. squirrel
    Yes it is. I think he drives on drag radials, he was only going 35 when we were behind him.
    porkshop, loudbang, Sharpone and 2 others like this.
  19. 41 GMC K-18
    41 GMC K-18
    C = Consistent.
    H = High.
    E = Energy.
    E = Exceptional.
    P = Performance !
    Bravo @squirrel ,
    Simply magnificent !
    porkshop, ffr1222k, squirrel and 2 others like this.
  20. RodStRace
    RodStRace
    Five over? That's a ticket! :D
    Carry on, Jim. We are following the progress just like you did with Cat and others.
  21. 19Eddy30
    19Eddy30
    from VA
    I seen when set record , Does anyone know engine combo ,I did not hear that ,
    Just SB Aspirated .
    Sharpone, 41 GMC K-18 and porkshop like this.
  22. squirrel
    He was driving 35 in a 50 zone
  23. squirrel
  24. squirrel
    My first p*** today. I plan to try again. Right lane. It was a good run
    Deutscher, bobss396, Thor1 and 8 others like this.
  25. Hellpig
    Hellpig
    No OD?
    LOL, I have 4.30s, I feel the pain!
  26. 19Eddy30
    19Eddy30
    from VA
    Looks Sb2 ?
    Or custom head on Ls , can not see front & low of engine
  27. 19Eddy30
    19Eddy30
    from VA
    @squirrel
    The second purple line boost ?
    I believe if able to spool up
    You would be right @ yr goal or
    Low 10:20's
    For some reason I can not load
    Yr data log that you posted
    Sharpone and 41 GMC K-18 like this.
  28. Not to get this thread too far off, but that vette is a 427ci LS based engine. In an interview he said canted heads, lots of camshaft and lots of compression.
    Now back to Jim...
    You are working on being bracket consistent! Its still weird to think of you with electronic ignition and electronic fuel injection
