9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. Crosley
    Crosley
    from Aridzona
    I had Ed Smith's Speed shop install a set of 4.56 Zoom gears in my 1968 Chevelle SS in 1971.. They were quiet.
    Tickety Boo, 41 GMC K-18 and porkshop like this.
  2. slowmotion
    slowmotion
    Installed Zoom 4.88's many moons ago. Don't recall them being overly loud. I wonder if they're cut at a different pitch, being subject to severe use (in most cases) (ala rock crusher gears)?
  3. squirrel
    Some of them were OK, some were noisy. It was long ago...
  4. squirrel
    I've been fiddling with the fuel and spark maps, to try to get a bit better highway gas mileage. It made about 10-12 mpg on Drag Week, which is rather lame for having EFI and a modern efficient engine.
    I added more spark at cruise, and leaned it out just a little bit. Took it for another test drive to Bisbee, it seems to be a little better. I might drive it up to Tucson tomorrow to see how it does on the AZ freeways, which I haven't tried yet.
    porkshop, SS327, 427 sleeper and 6 others like this.
  5. AmishMike
    AmishMike
    How lean? Cruise on flat land I used 19-1 seemed ok. A little gas dropped. 14-1 normal. 12-1 for power. Been a year that what I remember
    porkshop and Sharpone like this.
  6. squirrel
    I've only gone to about 14.5 on the AFR.
    The timing is about 36 at 3000 rpm under light load, it was not going that high before I messed with it.
    porkshop, Sharpone and 41 GMC K-18 like this.
  7. RodStRace
    RodStRace
    14.5 will be 'perfect' mix. You can easily run leaner at light load.
    Log knock and temps and keep them both 'safe'.
    https://www.hemmings.com/stories/ch...talytic converter. It was a short-lived glory.
    "The carburetor ran very lean–an 18.0:1 air/fuel ratio, well off the standard stoichiometric 14.7:1. What’s more, Chrysler was able to meet hydrocarbon, carbon monoxide, and nitrogen oxide levels without use of a catalytic converter."
    Yes, it developed the rep it still has, but if everything is not a goofy add-on mess that easily got out of tune and developed vacuum leaks it proves you can go that high. I wouldn't, but there is a hard number.
    Not familiar with the LS timing curves. A fella could lurk in a few forums and see what they like.
    As for freeway mileage, I have a feeling that the screen door out front isn't helping. :p
  8. squirrel
    I noticed that the Tahoe got really bad mileage towing Cheep at 75 mph, I slowed down to 65-70 and it improved noticeably. So there's some serious drag going on. I think it has more to do with the big old boxy greenhouse, but hey, it's been almost 45 years since I took any engineering cl***es.
    timing...they don't need much, compared to a BBC!
  9. RodStRace
    RodStRace
    I'm sure the back end is horrid for drag, but your additions out front are not helping.
    Just the nature of the narrow, short overhang nose. Can't tuck all that in.
    Don't suppose you want to bring the intercooler up and duct tape one of these on?:D
  10. squirrel
    Not really...I don't have one!
    and why are those headlights twisted from where they should be?
  11. RodStRace
    RodStRace
    used car dealer pic. You can guess the rest!
    Sure it's too wide anyway. Sure would look 'different'!
  12. 19Eddy30
    19Eddy30
    from VA
    Thats Pretty much what they get
    With 400 No overdrive ,
    I am 13 mpg Normal driving, cruise
    I am 14-8 AFR
    with th350 , have not installed the G-V yet . Mybe 2 more mpg.
    My cousin 32 5w 87 IRoc Tuneport
    350 , 700r Was 22 -25 mpg
    What was the Chevy 2 with 427 & G-V?
  13. squirrel
    Plan II got 10-11 mpg on my long trips with 3.89 gears and GV. Usually ran around 2500 rpm around 70 or so mph on the open road.
    So I'm doing better with this one, already.
    And I have the GV out of my truck that I can install in Cheep if I want to make it worth more money. The converter is pretty slippery below 3000 rpm though.
    I'm getting stuff ready in case I decide to drive Cheep out to LA and back to Tucson for the Duct Tape Drags.
  14. RodStRace
    RodStRace
    Anything your better half is interested in out in LA? Another shared road trip?
  15. 19Eddy30
    19Eddy30
    from VA
    Under stand , In my sedan I pulled
    427 sb 10 mpg out Installed a stock Vortec 350 with Carb intake & Holley Sniper 3:50 gear 29 tall tire th350 1,800 converter its 15 mpg , Definitely not Pinto and Vega mpg !
    I have a 4L80 , that trains is monster for my pre war cars ,I think I have a th200 thinking build, might try
    porkshop and squirrel like this.
  16. squirrel
    she and the kid will be hauling the Airstream to the drag strip the day of the cruise...so that won't work out... :)
    41 GMC K-18, Sharpone and SS327 like this.
  17. gene-koning
    gene-koning
    Cheep is a stack of bricks, aerodynamically speaking. All that air space under it is not helping either, I also suspect the under carriage air flow probably isn't much better the the air flow over the front end and then the air flow above the top.
    The faster you push the pile of bricks through the air, the worst the mpg drops.
    With my 49 Dodge pickup (also a pile of bricks, air flow wise), the difference between 60 mph and 70 mph over a pair of 200 mile back to back runs is 2 mpg difference. Air flow can hurt mpg a lot.
  18. loudbang
    More coverage in Bangshift today :)
  19. AmishMike
    AmishMike
    Correction. 16-1 was leanest on flat steady drive. Bad old memory 19-1 to lean
    porkshop, Sharpone and RodStRace like this.
  20. My daily is an 07 silverado 1500 crew cab 4x4 with 4.11 gears and 33s. 65mph cruise is 16mpg and 80mph cruise is 13.5mpg.
    If you can get ethanol free fuel it boosts my mpg. On long highway runs at 65 I flirt with 17.5mpg with rec 90 fuel.
    porkshop likes this.
  21. squirrel
    Drove up to Tucson today, visited my brother. We were looking at the engine and I noticed a rib was gone off the serpentine drive belt.
    When I was figuring out what belt to use back in May, I goofed up the routing direction, and ended up with it routed opposite from what I wanted, so the crank was pulling the belt from the alternator, then idler, then water pump. I got a belt the right length to pull the water pump first, then alternator, then idler. It's a spring loaded idler. I had removed the power steering pump, and mounted the alternator so the belt would go where it needed to.
    Anyways, on the drive home, the belt flew off and disappeared. I saw the battery light on and noticed the temp up to 200 degrees, so I stopped and put on the old belt again.
    Maybe something's not lined up perfectly, or ????
    I'll have to check it all out.
    also when we were at the parts store in tucson, ended up talking to a couple guys in the parking lot who are going to the Duct Tape Drags. Small world.
  22. squirrel
    I think I figured out the belt problem. The belt looked funny because it had shed one of the ribs. After looking things over, I discovered that the alternator has a 5 groove pulley, which doesn't work too well on a 6 rib belt! It hides under the intercooler pipe, so it's not noticeable.
    I'll just run it as is, and order a 6 groove pulley to use with a new belt, to fix the problem.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
  24. MAD MIKE
    MAD MIKE
    Way to go Jim!
    Late to the game with a lil' tech.
    8.8 found in Fox/SN95 cars was cast Fe.
    In '05, with the retro S197, Mustangs 8.8 is cast steel.
    Not sure on what other models also have cast steel 8.8s.
    Is there no filter or velocity stack on the turbo inlet?
    Just raw dogging the air?
    A bellmouth(~$30) on the inlet would improve linear airflow and compressor efficiency thus mo powa!
    Is there no fence or dam between the water radiator and turbo inlet?
    ****ing heated post rad air is killing your power.
    Even a piece of dryer ducting to get the turbo feed inlet ahead of the hot air off the back of the rad would improve power, or at least consistency.
    Intercooler would be more efficient if there was some pressure differential around it.
    An airdam and some fencing, or even some mild ducting behind the from the bumper down to the I.C. would improve air flow through it.
    Keeping air from under the Cheep would promote better cooling for both radiators, reduce drag increasing mpg, and help with keeping Cheep more stable at the top end, and highway cruising, by not riding that speed ****ing cushion of air under Cheep.
    I understand there was a budget and time crunch, a few small changes would make Cheep faster.
    Yes I know the big gaping hole up top isn't helping with aero, but can mitigate the barn doored-ness with a few more cheap tweaks.
  25. squirrel
    great ideas...and will probably get some of them done as time goes on. I thought about making something to keep the radiator air out of the intake, but it looked like too much work :) I also need to cut some holes in the bumper or just cut a big notch out of it, where it's blocking 1/3 of the intercooler. Adding some air dam to the sides of it would be pretty easy.
    41 GMC K-18, porkshop, SS327 and 3 others like this.
  26. squirrel
    got my new alternator pulley in the mail today, and installed it.
    And the weather forecast for this weekend has caused both of my potential t-n-t drag races to be cancelled/postponed. Oh, well.
    41 GMC K-18, porkshop and Sharpone like this.
  27. squirrel
    Took Cheep to the car show Saturday. Lots of curiosity about it, had fun. This is a picture from the local newspaper about the show, you can kind of see Cheep in the circle, and a few guys looking at it.
    I also decided to get a bluetooth interface for the Terminator X system. This lets me use my phone, or another device like a tablet, as a limited dash display, but with more features than the existing little 3.5" "handheld" screen that I now have stuck on the dash. The bluetooth module and the handheld screen both use the CAN bus interface to talk to the Terminator X, and I also have a USB cable that lets me connect a laptop to the system.
    I was pondering what to use for a device in the car...I don't really want to tie up my actual phone with it. There are some small tablets available that might work, but it would have to be 8" or less diagonal to fit in the middle of the dash, covering up the speedo/gas gauge. Then I thought about other phones, I have some old ones, and one of them would work for it. But you can also buy a new phone for $30 at walmart, which requires a purchase of data/phone carrier service to actually works as a phone. But if you just want to use it for a bluetooth display, or do things using wifi, you can do that without any extra expenditure. So, I bought a cheap phone at walmart, to use as a dash display. I still have to figure out how to mount it, which will likely involve Velcro.
    Here it is, updating the firmware on the new bluetooth module (which I stuck to the bottom of the Terminator X unit below the dash, emitting a blue glow).
    This computer/phone/electronics **** is pretty fun, although it can be slightly confusing to a old geezer. But I did get the new display to work, and also to data log while it's displaying info. That's the big problem with the other small screen, it can do one or the other, but not both! since I kind of rely on it to display warnings when things get wonky with the engine parameters, at the same time I want to log those parameters, I needed something extra, and now I have it. The new display is easy to turn on logging, while it's displaying it's data. It also has a configurable display, which means now I have to figure out what I want to see. (Oh...it also has built in GPS speedometer, using the phone's sensor)
  28. RodStRace
    RodStRace
    What you can figure out by using a 30 dollar electronic to display stuff from the much pricier system would probably be a good separate thread.
    Still planning on Duct Tape this weekend?
    https://www.ducttapedrags.com/
    porkshop, Sharpone, SR100 and 2 others like this.
  29. squirrel
    We're planning to go...
    although the extra buzzing in the transmission has me a little concerned. Like it's cavitating, worse when it's cold, but doesn't really go away.
    I changed the pressure regulator spring, put in the stiff orange one from a Trans Go kit. And put a new filter in. I don't know what else could affect it.
    hmmm....
    Oh, I went for a little drive with the new display stuck to the dash, just right on top of the plastic in front of the bottom of the gas gauge. The gps speedo does not work very well. I was able to make a couple data logs, but also failed on one.
    and I was playing with the 2 step, it got up to zero pounds boost at just under 2000 rpm, and the car was not pushing through the brakes. Maybe I'll increase the rpm a bit at a time and see what it does. I pulled the exhaust flap off for this test.
  30. hotrodjack33
    hotrodjack33
    Sadly, lost me at " bluetooth interface for the Terminator X system."
    Not surprising though...my flip phone sometimes confuses me.:mad:
