A Banjo Bolt & Fitting Question:
Discussion in 'The Hokey Ass Message Board' started by 4woody, Jan 11, 2014.
  1. 4woody
    4woody
    I need a banjo fitting to fit the 18mm O-ring inlet on a power rack. Fittings that say they're for power steering applications are not readily available locally, but I found one that is intended for the cooling line on a turbo intercooler.
    Any problem using the intercooler banjo for power steering? Too much pressure for it??
    Looks like this:
  2. JEM
    JEM
    You mean like these?
    http://www.unisteer.com/power-steering-pumps-accessories/18mm-banjo-fitting.html
    Seriously, any decent steel AN/JIC fitting should comfortably handle power steering pressures (600-1600psi depending on your pump/application) but you need real hydraulic hose and fittings, not steel-braided AN.
  3. 4woody
    4woody
    Yep- But the Unisteer fitting is not available locally, but the pictured type is. I didn't know if it was literally the same, or built to a different (ie lower pressure) spec.
  4. joel
    joel
    Try the guys at Earls Indy. They have a website, but that is only a portion of the stuff they carry. great to deal with and fast.
