Same O' Same O', every Summer. When I'm ready for the A/C, it ain't ready for me. My idea this time is to purge the system, and replace all the O rings to see if that stops the leak. My question, can I recharge/refill my unit with the A/C Pro "stuff" now available in most parts stores? Anyone here ever use it? Is it OK? Any down side? Jack
How old is your system? Will it run on 134a? You can convert the older systems, but I am not an expert. Check around & see.
A minimum of 500 microns, preferably more. A micron gauge is just a more accurate vacuum gauge. If you have a "traditional" set of gauges, then you want to pull a vacuum of 29 or greater inches of mercury (inHG)
Mopar Jack, your lucky. My A.C. on the 56 Chrysler is the vent window. LOL. Do you have a picture of the old girl?Thanks.Bruce.
Evacuate and pump down the system. Recharge with oil and freon and use a "sniffer" to locate the leak.
I do have a picture, but I'm kinda computer challenged. But I'll try. If I'm able, where should I send it?
Evacuate the system, charge it with nitrogen, and find the leak. Dish soap and water in a spray bottle has been more effective for me than sniffers, cheaper too. Then vacuum it down again and charge with 134A. Sent from my iPad using H.A.M.B.
