Technical A/C R12 Recharge
Discussion in 'The Hokey Ass Message Board' started by Jalopy Joker, Jul 25, 2025.
  1. Jalopy Joker
    Jalopy Joker
    have a '65 T-Bird with original A/C system. blows cool air but, not cold air. guessing that a recharge boost will make the difference since not serviced for a long time. there are aftermarket subs***ute R
    12 compatible products available for doing recharge at home. anyone used any of these with good results? do not want to switch to R134a.
    dana barlow and chryslerfan55 like this.
  2. BJR
    BJR
    You probably only need one can or less, buy the real R12. I see it at swap meets and on marketplace for $20 to 30 per can.
  3. saltflats
    saltflats
    from Missouri
    Something that old will have a sight gl*** to check to see if it is low.
  4. ckh
    ckh
    I would make sure there are no leaks before adding any freon. An AC shop will have a "sniffer" that makes a noise when it detects a leak when held near any connections in the system. My dad used to
    service AC systems, and a lot of times when the system did not blow cold air it was because of a leak.
    As I recall he used a halogen "sniffer" to detect leaks. Worked really well. R-12 is not hard to find. If
    you have trouble finding any, send me a PM.
  5. Kevin Ardinger
    Kevin Ardinger
    Don’t hook the can to the hi side or the can may explode!
  6. Black Panther
    Black Panther
    from SoCal
    Look up EnviroSafe..supposed to be compatible with R12, it's cheap and available online. There are other websites where people have used it and are happy with it...
  7. deathrowdave
    deathrowdave
    from NKy
    Damn my Friend , I wish I was near to you , I have a 30lb cylinder and nothing to use it in . I would fill it for you . But it does need to be leak checked 1st thing .
    rod1 likes this.
