a/c
Discussion in 'The Hokey Ass Message Board' started by shockley_67, Jul 9, 2013.
  1. shockley_67
    shockley_67
    I sure like the look of the early mustang under dash unit. And using a low mount should hide it enough but just going to vintage air and being done with it is probably the best idea. Or I could move somewhere not quite so close to the sun!
    Thanks guys for all the replies
  2. pitman
    pitman
    The driveshaft driven...works fine...for electrons, or BTU's...
    as long as you...move! :rolleyes:
  3. saltflats
    saltflats
    from Missouri
    Maybe if you are running a standard trans you could run the comp off a PTO drive
  4. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I'll run my AC all day long and you can call me a woose all you want and see if I give a ****!:D
  5. blowby
    blowby
    from Nicasio Ca
    Small A/C home units, like this one, apparently take less than 1 hp to run, if I'm understanding the specs correctly. Why does a car unit require more?
    http://www.frigidaire.com/products/...iers/Portable-Air-Conditioners/FRA053PU1.aspx
