A chrome polish/rust remover that works?
Discussion in 'The Hokey Ass Message Board' started by Ranunculous, Jan 14, 2008.
  1. Ranunculous
    Ranunculous
    Howdy all,
    Can anyone clue me into a good rust remover for an old set of chrome reverse? Then,a good chrome polish?
    I've heard that WD-40 and aluminum foil might take the cornmeal rust off?(Well,it's not that bad...but rusty).
    Thanks!
  2. HotRodFreak
    HotRodFreak
    I use WD-40 and 000 steel wool
  3. Mattilac
    Mattilac
    Some real muscle and a bunch of gritty wire-brush wheels on your drill or air tool.
    One time I took a complete front axle and spindles down to metal in the course of two solid full days of man-handling it and breathing in the old toxic dust.
  4. skipperman
    skipperman
    NAVAL JELLY ... any auto supply......
    .......jersey Skip
  5. ketchup and aluminum foil, it works!
  6. slddnmatt
    slddnmatt
    000 steel wool
  7. budd
    budd
    the white stuff in chicken poop mixed with sand, i swear.
    ok i have never tried chicken poop but i have used this many times, it can leave tiny marks but if what your using it on is allready rusted then who cares,
  8. 55chieftain
    55chieftain
    Rust-eze bumper ointment
  9. zbuickman
    zbuickman
    fine steel wool as stated 000:)
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    ive used some stuff called Blue Max..it seems to work nice
  11. Eryk
    Eryk
    Yep!
  12. edsel
    edsel
    I use Ford Custom Metal Bright P/N ZC-15 and if its sorta heavy rust I use a small screw driver with it and lightly s****e the rust then reapply the ZC-15 works awesome for me.
  13. junkyardroad
    junkyardroad
    from Colorado
    Use a product called Flitz. Speedway Motors has it. It works great for all kinds of metals. I even had great success using it to remove overspray from my carbon fiber. It probably won't to heavy rust though. Expensive but worth it.
  14. slam49
    slam49
    from tulsa ok
    i used mothers polish on by grill. it had little rust speckles, lots of time and elbo grease in very small circles, looks very nice now.
  15. Ranunculous
    Ranunculous
    Thanks everybody! I appreciate all the responses and will get to work against the "demon rust!"
    The wheels are sentimental and have been in the family a long time.You know how that is?
  16. tommy
    tommy
    I bought a 62 Corvette with the factory chrome wire wheels for 800.00 (that will tell you how long ago it was) I used Navel Jelly and an artist oil paint brush (short stiff bristles) to get into the back spokes and center hub. I was amazed at how well it worked. Don't rush it. Let it work. Then the fine steel wool if you can get to it with your hands.
  17. charleyw
    charleyw
    I've used much of the above, also "guncotton" for finer polishing afterwards. It's chemically treated cotton or fiber. Eagleone sells it as well as others. FWIW
  18. glenn33
    glenn33
    from Browns, IL
    Eagle One makes a fleece polish called Never Dull that works great. I've used it on lots of chrome wheels with great results....
  19. dickster27
    dickster27
    from Texas
    I am really surprised that some of you "old timers" haven't suggested by far the best rust cleaner. Go to the kitchen and steal one of your wife's brillo soap pads. Soak it good and you will out perform every other suggestion on here. Try it, you'll see what I mean. Just be sure to keep it wet and it cleans, not scratch.
  20. MBL
    MBL
  21. CraigKrage
    CraigKrage
    from central IL
    Also there's a product called No. 7 Auto Polish it works good.
    For rough jobs I've used an SoS pad and follow it up with mother's polish.
  22. Asphalt Outlaw Hero
    Asphalt Outlaw Hero
    from Dixie
    Quick Glow is GREAT! I used it for years on motorcycle wheels.A guy in a bicycle shop turned me on to it.
  23. Lynnlo
    Lynnlo
  24. 53 COE
    53 COE
    from PNW
    Wood Bleach The easy way - not that it will do the OP much good - 5 year+ old thread....
    BEFORE and AFTER.......
  25. 226 flattie
    226 flattie
    from orange,ca
    I have use 000 steel wool and the finished by polishing with wenol metal polish . Works great
  26. 0000 steel wool
    000 will scratch
  27. BobMcD
    BobMcD
    Steel wool and chrome polish.
  28. something called comet kitchen cleaner actually does wonders on rust stays away for a good amount of time , but its kinda rough on the shiney stuff but if you follow it with some good polish it looks great
  29. Coca-cola and aluminum foil
  30. blakeusa
    blakeusa
    from CT
    www.quick-glo.com
    Stuff is amazing, Have been working on cars and bikes for 35 years and this product has been around since 1957.
    Its the go to rust and polish at many restoration shops.
