Technical A different question on brake pedal ratio
Discussion in 'The Hokey Ass Message Board' started by lostone, Jul 24, 2023.
  1. lostone
    lostone
    from kansas
    Alright I've been working on the dash (38' ford) in my 31 tudor and setting up the 1" tube cage in the cowl to mount my under dash master cylinder, steering column etc to and trying to figure out how it's all going to fit and mount.
    I'm using a corvette style master and I have the 90° pedal****embly from a dodge van that I will cut down to fit nice and snugly under there.
    I will be running front disc, rear drum and MANUAL brakes so I already understand a ratio of 6 to 7:1 is where I want to be BUT here is my question!
    All the charts on ratio's I looked show a hanging pedal with the top hole being the pivot and the lower hole being the master cylinder and the math they show for this set up, so with mine it's the opposite, the upper hole will be the master cylinder and lower hole the pivot. So how do I figure out the ratio properly?
    I'm great at math and numbers but for some reason I just can't get my head rapped around it. So if I have 2" between the holes, top master cylinder, bottom pivot, would I need 12" from bottom hole to brake pedal to get 6:1 ? Am I correct?
    Thanks guys, getting old I find simple problems become harder for me to figure out !!
    brEad likes this.
  2. tb33anda3rd
    tb33anda3rd
  3. pprather
    pprather
    lostone and LWEL9226 like this.
  4. jimmy six
    jimmy six
    What is the corvette style MC piston diameter? Was the Corvette style MC made for rear drum brakes or discs? What rear drum brakes do you have? Diameter, width of shoes, and diameter of the wheel cylinders. Are your front calipers 2 or 4 piston?
    All these items are important when engineering your own system. I have non power disc/drum and each question I’m asking you was asked of me.
    lostone likes this.
  5. lostone
    lostone
    from kansas
    Thanks guys!!
    Front gm metric calipers 2.38" piston
    Rear ford 15/16" bore wheel cylinder
    Ford 11" x 2 1/4" brake shoes.
  6. jimmy six
    jimmy six
    My MC bore was 7/8”. I’m sure the Corvette style is larger if disc/disc. My ratio was also 6-1. If your MC is 1”, you maybe ok but 1-1/8” may take more foot pressure than you will like. Rears are the same..Good luck.
    lostone likes this.
