Technical A/F Meter?
Discussion in 'The Hokey Ass Message Board' started by ‘28 RPU, Jan 25, 2026 at 11:01 AM.
  1. ‘28 RPU
    ‘28 RPU
    I want to install an A/F meter and would appreciate some advice. If there is a decent quality 2” meter I would probably go with that but I’m not married to the idea of an in dash meter. I don’t want cheap and I don’t want big bucks either, something in the middle somewhere would do.
  2. 19Eddy30
    19Eddy30
    from VA
    Holley , Autometer & other's make
    bolt / clamp on No weld
    & use a gauge cup , then remove
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’ve got this one “temporarily” set up in my T. Was a low cost kit complete with sensor, weld in bung, and full wiring harness. Trimmed the harness so I could connect with alligator clips, and tucked the gage down in the corner below the seat. Guess a couple years isn’t so “temporary”, but it’s nice to see what’s goin on up at al***ude. I’ll pull it out someday…
    Driver50x, winduptoy and mad mikey like this.
  4. Steve Reddy
    Steve Reddy
    I use a Innovate dual sensor on my car but it has twin turbos. It works very very well. I welded O2 bungs into my exhaust collectors, a 363" V8 ford.
    Driver50x and winduptoy like this.
  5. 05snopro440
    05snopro440
    Have you found it helpful for tuning?
    lothiandon1940 likes this.
  6. Joe H
    Joe H
    I have this one in my truck, https://speedhut.com/gauge-applicat...**og-out-o2-gauge-8-5-18/?dd-link=0ldtcryzj5b I went with the bigger diameter for easier to read. I picked color and font that closely matches my stock gauges.
    It was a tremendous help in getting the dual Carters to run better, fuel mileage went way up, smell went down, and over all driving much improved. I have it mounted and watch it more then the speedometer, it will show the difference when switching fuel stations or fuel grades and temperature outside. They went up in price since I bought mine. Mine was acting up not reading right, so I called asking to purchase a new O2s, fellow on the phone ask for my address and sent a new no charge, no questions asked. Can't beat that for customer service!
  7. RmK57
    RmK57
    mad mikey likes this.
  8. VI Lonewolf
    VI Lonewolf
    Not Kevin but I use the Innovate with 2 sensors. Absolutely helps. Can also see different tps. Because each one of mine is sampling 4 cylinders you may have to tweak a little to hit the sweet spot.
    Also any uncured silicon will toast the sensor. Another thing that can hurt them is gas additives.
    Driver50x likes this.
  9. bigdog
    bigdog
    I'm running an Autometer gauge. If you've never run one on anything it will make you realize how screwed up all your other cars have been. "Out of the box" carbs are usually not even close on a modified motor.
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    The A/F gage was added to help me dial in my custom made dual Winfield setup. Fuel ratio adjustments are easy when you can simply watch the gage, but next is the accelerator charge. Cool thing is I can see the live feedback when romping on the throttle, bummer is that custom components have to be made to adjust the accelerator charge volume. But at least I can see what it’s doing, takes a lot of the guess work out
  11. 05snopro440
    05snopro440
    I've been having a surging issue on heavy acceleration. I got a lot of it solved, but think part of what remains is still carb tuning. I've been considering trying an AFR gauge to try to further resolve the issue (or tell me if it's the converter instead).
    Tickety Boo likes this.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Jes sayin'. I spent way more than a decade reading the Fordbarn Early V8 page.
    There was a camshaft guru may he rest in peace:( Ol' Ron Halloran.
    He had a practical approach to all modifications.
    Always he would insist:) on using an AF meter.
  13. 19Eddy30
    19Eddy30
    from VA
    One needs to under stand , Carb & MFI is not EFI . Tunning with a O 2 is a big
    Help & understanding what going on in fueling / Afr's But not each individual cylinder
    unless you use a O2 or Etg on each separate bank. If O2 is installed it's average of all those cylinders Not what going on in each separate intake runner.
    There a trade off you either tune for
    Idle to Cruise ,
    Or Cruise
    Or Cruise to Wot
    Or Wot .
    There is Only so much you can do with One or multiple carbs feeding multiple Cylinders ,,,
    Intake design other factors , to get to Close what Efi is , is to have One carb per cylinder ,
    Runner length matters , Some short compared to other being Long ..
    You can play with different spark plugs
    Per cylinders ,
    Heat range & plug designs .
    You can go deep in Rabbit Hole trying to be Close to perfect Afr , Economy to Performance.
    My self if I do not have control over
    each separate cylinder I instal the O2
    On the "Leanest " of the Cylinders & make that One happy & tune off it .
    Again its Give & Take with a Carb or
    Multiple Carburetors ...
    & you have not discussed other factors
    of engine workings ,
    Just for example , We say Engine
    Let's say a 4 cly , but Each cylinder is a separate power / Energy maker
    So each cylinder needs separate requirements , But We try to balance all 4 equal ..
    Bla Bla Bla
    Yes O2 good tool to have , But you can get lost ,chasing your tail watching the numbers from Idle ,Cruise , WOT
    RmK57 and mohr hp like this.
  14. pprather
    pprather
    If you want to take the O2 sensor to the next level, with a carb, check out
    www.thecarbcheater.com
    It's not efi, but it fine tunes the carb in real time over varying loads and rpm's.
  15. bigdog
    bigdog
    Yes O2 good tool to have , But you can get lost ,chasing your tail watching the numbers from Idle ,Cruise , WOT[/QUOTE]
    This is very true, you can't just chase what is supposed to be an ideal ratio, you have to pay attention to what the motor says it wants. As an example, my big block Mopar will get a lean surge at cruise if it gets over about 15/1 at cruise, but a lot of what I've read says cruise can be much leaner than that for fuel economy. It all depends on your build. I found David Vizards book "How to Super Tune and Modify Holley Carburetors" very useful.
    Driver50x, pprather and Tickety Boo like this.
