a few handy part numbers
Discussion in 'The Hokey Ass Message Board' started by 36-3window, Aug 21, 2010.
  1. over the years i have saved the part numbers that worked well for me so i could use them on future projects, here are some of what i have(in no particular order) ...what do you have?
    SBC in a `28-`34 lower radiator hose.....Napa # 7286. #7209 often works on the upper if using the angled water neck
    sbc in a `40 ford lower hose......napa #8685
    `68 mustang drum/drum master cylinder... #10-1485
    fittings to adapt it to 3/16" lines.......edelmann #'s 258302 and 258350
    sbc spin on oil filter adapter for old canister type motors....Wix #24061 , same as napa 4061
    Wix filter for flathead ford canister filter....# 51006 , fram C4P
    wheel studs for buick drums on `47 ford hubs......napa @ 641-1145 , dormann #'s 610-120 and 610-132
    wheel studs i use when i redrill f100 brakes to 4-1/2" bolt circle.....napa# 641-1169
    lug nuts for old ford wheels , 13/16 hex.....Dormann #611-016
    axle nut for `37-`48 ford spindles......dormann #615-067
    8" ford axle seal.....CR # 13700 pinion seal # 18100
    9" ford axle seal......#13738 small bearing , # 15142 big.... pinion seal # 18833
    vega steering box seals......CR #'s 9818 and 6130
    sbc motor mounts ....napa # 602-1054 , th350 tranny mount # 620-1031
    sbc fuel pump push rod.....napa # 6101181
    sbc harmonic balancer repair sleeve.....napa # 600-2016
    speedo cable from th350 tranny to SW/VDO etc speedometer with 5/8" threads....Pioneer # CA-3002 for 63" long and CA-3004 for 83"
    i have many more...what do you have to add?
  2. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    Always good to keep part #'s that work.When I'm back from Kona I'll add some I like this link should have a sticky in tech .
  3. scrap metal 48
    scrap metal 48
    Good list to have.. Thanks for posting......
  4. Rehpotsirhcj
    Rehpotsirhcj
    1. Northwest HAMBers
    I'll second that.
    subscribed
    thanks for the numbers
  5. 1941coupe
    1941coupe
    thanks for sharing thats what its all about...al
  6. thanks... to be honest , i haven't been on here much lately because i haven't found much to be useful , been busy doing things. then i realized i haven't posted much that would be useful to someone else. so here is my try at being useful. i know you guys can add a lot more!
    a few more:
    spin on filter adapter for later SBC's that are not canister type (many new crate motors do not come with it)...GM #3952301 , Pioneer #839049
    air filter for 50's olds/caddy air cleaner....Fram # CA3492 , Wix # 42096
    `70 AMC Gremlin drum/drum master cylinder , basically the same as the famous `68 mustang except the ports are on the other side , that can help in a tight situation.....20-1373
    90 degree 1-1/2" ID radiator hose about 4 inches long each way , can be handy sometime when splicing two hoses.....Napa #777
    Gates powergrip thermoplastic clamps for radiator hoses....32948 for the 1-1/2" id upper hose and 32954 for the 1-3/4 id lower
    SBC flexplates:
    153 tooth internal balance with both 10-3/4 and 11-1/2 torque converter bolt pattern.....napa # 600-5021 or pioneer # FRA112
    168 tooth internal balance both patterns....napa 600-5000 ,pioneer # FRA100
    153 tooth external balance (for the one piece rear seals) ....napa # 600-5061 (10-3/4 only)
  7. brad2v
    brad2v
    I'm a partsguy by trade, just came across some very compact hood hinges that should work on a variety of cars. Chrysler part #'s are 5104404AA and 5104406AA. They're listed for a Sprinter van (you know, those ugly UPS vans)
  8. mgermca
    mgermca
    kidcampbell71 likes this.
  9. Its all that little stuff that gives the biggest ass cramps.
    Great to have and now is in my subscription vault.
  10. floydjer
    floydjer
    Spicer 5-3022x. Life-saver u- joint.
  11. r8odecay
    r8odecay
    Here are a few I have handy, 51 Cadillac:
    Coil – AZ C809
    T-Stat AZ 15478
    Regulator – AZ VR605
    VAC ADVANCE UNIT GM DELCO/REMY P/N 1116056
    Points Delco/Remy 1918148
    Duralast DR1074MV
    ECH CS778A
    Condenser Napa
    MPE RR174SB
    ECH RR174
    RotorNapa ECH RR 159
    Dizzy CAPDuralast DR972
    Napa ECH RR 158
    Napa ECH RR1580
    Clevite Rod Bearings CB348P
    K-W VOLTAGE REGULATOR# C2726, 12 VOLTS, 35 AMPS ,
    Spark Plugs:AC Type: 48x
    Champions: #58, RJ18YC
    Autolite: #86
    Oil pressure switch: Borg Warner S303
    Rear Brake: Raysbestos WC6092
  12. happy hoppy
    happy hoppy
    49-51 Ford related, SBC conversion.
    radiator hose,
    upper Gates-21794. lower Gates-20957
    shocks for stock suspenion lowered 3" front, 4" rear
    front, Monroe-5821 rear, Monroe-31000
    front coil springs, lowers 3"
    Ford aerostar-Moog CC850
    SBC stock exhaust manifold that clears stock Ford steering box.
    1984 Camero-Firebird.
  13. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    a volkswagon bug coil at schucks is the same used for many applications, and is the lowest price while having the same part number.
  14. old thread , thought i'd add another part number i've found handy
    O'Reilly # h1414-2 wheel cylinder link. works on many ford drum brakes , often missing on 8 and 9" rears
  15. 3wLarry
    3wLarry
    from Owasso, Ok
    what asshat gives a good info thread a one star rating?...this could be a great thread if more contributed their knowledge.
  16. 31Apickup
    31Apickup
    here's one. Front tube shocks for your Model A, 32-34. Use a Monroe #5752 for a 1950 Plymouth. They have the upper cover so they have the old style look. They are around $22 each at O'Reilly's.
  17. Donut Dave
    Donut Dave
    Anyone have part numbers for 9" Ford rear brake parts (Springs, clips, pins, wheel cyl. link, wheel cyl. 7/8", 15/16", 1", 1-1/8 etc.)
  18. tfeverfred
    tfeverfred
    These were gathered while working on my SBC powered T Bucket. I hope they help.
    Short water pump: CWP-373 Duralast (Autozone)
    Alternator belt (using lower alt. mount): 7425 Gates, I believe
    Rear transmission seal TH350: Fed. Mogul #9613S
    SBC upper radiator hose: Gates #20416
    SBC lower radiator hose: Gates #21956
    SBC upper radiator hose, when using centered thermostat housing: Gates #21631
  19. good post guys.....
    all I can add at the moment....bringing home another project - two extra dose of BC powders....washed down with your choice of liquids...
  20. old thread , since i have been asked for a few part #s lately i thought i'd bring it back up. anyone have anything to add?
  21. fordcragar
    fordcragar
    from Yakima WA.
    At Rockauto they are $16.23
    http://www.rockauto.com/catalog/moreinfo.php?pk=294357
  22. Rusty
    Rusty
    Good stuff !
  23. old thread..anything new to add?
    i had previously mentioned `37-`48 spindles nuts as Dorman 615-067 but not the washers...they are 618-005
    Bowtie Coupe likes this.
  24. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I just bought Monroe 5752 shocks Rockauto $16.52.
