A Frame Question
Discussion in 'The Hokey Ass Message Board' started by mikey502, Jan 5, 2009.
  1. mikey502
    mikey502
    I've got a 29 A frame I am going to be building up and have been looking at pictures and threads on the suicide front ends however I still have some questions before I go through with it all.
    I tossed together a crude drawing for this, hopefully it helps. What diameter tubing/pipe would I use for the cross member? Do I use a smaller diameter pipe and fit it at the very front of the frame (A) or do I use a larger diameter piece and cut the frame back some (B)?
    And once that new cross member is in, I remove the old one correct?
    -Mike
  2. Chicken Scratch
    Chicken Scratch
    If going with a suicide mount you have to move it further forward than where the stock model A mount used to be. The radiator still goes where "B" is and then the tube goes where "A" is. If this is on an existing stock model A frame, the best way to probably go is to cut off the frame horns and extend the frame with some rectangular tubing, maybe piecutting a little out of it to keep the taper going and then make the suicide crossmember out of 2-1/2". -Jimbob
  3. mikey502
    mikey502
    Alright thanks a bunch exactly what I was looking for. :) Now the tough part will be cutting the frame. :)
  4. mikey502
    mikey502
    Have another question about this type of front end:
    1 determines the amount the front end is dropped correct? And what widths do I want 2 and 3 to be roughly?
