A good Grease Gun???
Discussion in 'The Hokey Ass Message Board' started by jimcaf, Mar 28, 2010.
  1. jimcaf
    jimcaf
    from san diego
    Iv got 3 and they all work like ****ola,,,whats a good one to buy,anyone have reliable one???,,,thanks jim
  2. Adam.Perrault
    Adam.Perrault
    from Phoenix AZ
    I have always liked the 12v lincoln grease guns. the 14.4v blow the heads apart!
  3. Side
    Side
    Blue Point seems to be the best so far.
  4. dalesnyder
    dalesnyder
    yep, rechargable lincoln all the way.. But nine out of ten technicians do not know how to put a cartridge in correctly.. Usually not the guns fault.
  5. davis574ord
    davis574ord
    Yeah i like the blue point myself!
  6. 61bone
    61bone
    I have a 12v Lincoln the I've used for 15 years and is OK. My 2 Lincoln hand guns were bought new in 57 and still function flawlessly.
    Tip- When installing a new cartridge, take some grease from the bottom of the tube and fill the top end of the tube where the pull tab was. Start the holder 1 thread in the head and release the pressure piston , then finish tightening the tube.
    Yes, you do have to remove the metal seal. Breaking the pull tab off is not enough. Don't ask.
  7. norms30a
    norms30a
    61bone, good advice, I usually have some trouble with air on a new fill so I will try what you said, thanks.
    I go through lots of grease in the spring and fall during field work.
  8. EXACTLY!! I was going to ask him how he loaded the gun.
    I am 46 years old and have used a grease gun ALL my life on projects and cussed all those years, at the age of 30, I was shown the correct way by an older dude that chuckled a lot at me. He showed me the clean way and the way that obviously works much better than the way I had been doing it the 15 or so prior.
  9. Licensed to kill
    Licensed to kill
    from Alberta
    I have a couple of the lincoln manual guns and don't like them at all. I have several Ultra Pro guns from NAPA and they better but the Lincoln 12V rechargeable is the one that I carry with me in the summer in the field and the only one I use in the shop.
  10. redlinetoys
    redlinetoys
    from Midwest
    I have had several grease guns that have been junk too. Good to hear some of this information. Thanks for the tips.
  11. jimcaf
    jimcaf
    from san diego
    Thanks much for the good info,Im going to try loading one of them the way 61Bone recommends before they end up in the trash.All of them do have the problem of an air pocket and not feeding,,,thanks again jim
  12. McDeuce
    McDeuce
    from Wisconsin
    I bought one in the 70'S at NAPA, a mechanics grade one and have had it ever since. All I have ever done is change the hose on it.
