Hot Rods A good video about Ford Y Block top end oiling
Discussion in 'The Hokey Ass Message Board' started by Mummert, Nov 15, 2022.
  1. Mummert
    Mummert
    It never hurts to spread good info.
  2. airsix
    airsix
    I’m really enjoying the y-block videos you’ve been publishing lately.
    Deuces and Mummert like this.
  3. Mummert
    Mummert
    Thanks were working on plans for more, but we have to work to, it a little tougher than I thought it would be.
    Deuces, Desoto291Hemi and williebill like this.
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Outstanding information.
  5. Mummert
    Mummert
    Hopefully it helps get the word out.
    y'sguy, Deuces and Jeff Norwell like this.
  6. guthriesmith
    guthriesmith
    Great info! Timely as I am hoping to rebuild a 312 this winter. :)
  7. It sounds like you like the idea of plugging the overflow tubes in the rocker shafts, any worries about less oil to the timing chain or dist drive?
    Oh, and thanks for the video.
    Jeff Norwell likes this.
  8. Mummert
    Mummert
    No. We have never seen abnormal wear with those parts. I can't recall the last time I changed a worn distributor gear. Timing chain, buy a good one never look back.
    There is too much interface pressure between the rocker and the shaft under lift conditions to not have pressure fed oil. Rocker arm wear due to poor top end oiling has always been the achillies heal of the engine. 5 minutes worth of machine work on the cam a couple set screws for the rockers problem gone never to return.
    Ford dropped the ball hard on this and the engine suffered because of it. But its such an easy fix.
    y'sguy, Budget36 and 46international like this.
  9. Thanks for the advice
  10. Budget36
    Budget36
    I’ll never have a Yblock again, but enjoyed the watch.
